HappyAndy
HappyAndy New Reader
10/5/08 5:52 p.m.
Hello everyone. my brother-in-law needs some help with a problem he is having with his 1998 V70xc. It is smoking, running hot and losing alot of motor oil. It also seems to be having a pcv or blow-by problem, smoke and oil mist coming out of the oil fill cap and dipstick tube. He says that it is running normaly aside from the smoke, but I noticed that the I/C hose was colapsing when the engine was revved up, leading me to suspect a siezed, or faulty turbo, but that wouldn't cause blow-by, and should also cause obvious power loss. What do you guys think?
NickF40
NickF40 GRM+ Memberand New Reader
10/5/08 5:57 p.m.
RUN BOY!!! GET A HOSE TO PUT IT OUT!!
Travis_K
Travis_K Reader
10/5/08 6:11 p.m.
Melted piston? Id at least do a compression check.
HappyAndy
10/5/08 6:15 p.m.
Travis_K wrote: Melted piston? Id at least do a compression check.
I plan to later on when I com back with my work truck & tools.
CrackMonkey
CrackMonkey Reader
10/6/08 8:18 a.m.
Turbo is failing. Oil seals in it are leaking oil into the intake path.
HappyAndy
10/6/08 8:55 a.m.
CrackMonkey wrote: Turbo is failing. Oil seals in it are leaking oil into the intake path.
Is the blow-by/pcv issiue likely related or unrelated?
iceracer
iceracer Reader
10/6/08 10:30 a.m.
The pcv is supposed to create a vacuum in the engine internals re;crankcase. Excessive blow-by would make it redundant.
CrackMonkey
CrackMonkey Reader
10/6/08 11:01 a.m.
HappyAndy wrote: Is the blow-by/pcv issiue likely related or unrelated?
Probably not, the engine is probably dying as well. Leak-down test?
Did he jack up the boost or something?
HappyAndy
10/7/08 11:00 p.m.
checked into this more today. turbo is not seized but the seals are leaking oil into the intake side of the turbo. the I/C was half filled with oil. draining the oil stoped the I/C outlet hose from colapsing. I also did a compression test. All 5 cyls were between 170 psi & 155 psi, OK considering my BIL doesen't like to change oil. boost pressure is stock (lpt 7psi I think). So the turbo needs a rebuild, and the pcv system is hopefully just clogged w/ oil.
Travis_K
Travis_K Reader
10/8/08 7:41 a.m.
Hmm, sounds like it may be ok with a new turbo. If he doesnt like chaing oil often/using synthetic, id suggest to him to avoid turbo cars in the future.
CrackMonkey
CrackMonkey Reader
10/8/08 7:51 a.m.
Eh, I go by the ECU recommended oil change intervals with my V70T5. That ends up being anywhere from 5k to 7k miles between changes, IIRC.
GameboyRMH GRM+ Memberand Dork
10/8/08 7:56 a.m.
iceracer wrote: The pcv is supposed to create a vacuum in the engine internals re;crankcase. Excessive blow-by would make it redundant.
Actually a PCV valve won't open just because the pressure is greater on one side than the other...there has to be a vacuum on the "outside" end or it'll stay good and shut no matter how much pressure builds up on the crankcase side.
KDyXHfv2DIkccwDkieBF5e5bblTeNfSDqL6E0bCNjql38jyPtxnbkLqYfwNksUE0
