thedanimal
thedanimal Reader
2/26/16 10:55 a.m.
In reply to Ashyukun:
Thanks! I used this It will haze up again, but usually lasts 6 months or so, then I go back with plast-x and reseal. I haven't tried the clear coat trick yet, but I may have too.
car39
car39 HalfDork
2/26/16 11:30 a.m.
Had good luck with the BG kit because it came with a sealer to protect what you had already done. Just be careful when drying it with heat, because you can damage the plastic. (Voice of experience)
wlkelley3
wlkelley3 UltraDork
2/26/16 11:46 a.m.
NickD wrote: Anybody tried the bug spray and old sock trick?
Yes, Tried after talking with a local LEO and seeing that he did it on his cruisers light bar. Used OFF on my RX8 and it did a great job of removing the haze with very little labor. It was streaked afterwards but that cleaned up very easily with a cleaner wax. Was amazed at how long between applications, only had to do it 2-3 times a year to keep clear and only takes about 5 minutes. Takes longer to dig the stuff out to do it.
tfRz3As0FH9WkvlCHJwCfOhZqCiVKOWldhyqNCOd7y5GoX4wfSjwGqrFVcpFKQVn
