DILYSI Dave
DILYSI Dave SuperDork
6/27/11 3:50 p.m.
So, going to be fabbing up some individual throttle bodies in the coming weeks. Using CBR954RR throttles. They have a 45mm opening, same as a Weber carb. Do a bit of math and it turns out 1 7/8 x 18 Ga header pipe is also 45mm ID. While I can find short velocity stacks all day long like this...
...I plan on making some long tube runners to test as well.
For the short runners, the chrome plated steel ones like above are fine. But for the long tube fabricated ones, I'd like to find some out of stainless. Any ideas?
KATYB
KATYB Reader
6/27/11 3:58 p.m.
make your own is all i have for you.
fasted58
fasted58 HalfDork
6/27/11 4:07 p.m.
for testing purposes why not fabbed steel exhaust tubing in various lengths w/ hi-temp paint n bake till you find the correct length then do the SS
KATYB
KATYB Reader
6/27/11 4:18 p.m.
or keep the mild steel and get it chromed or powdercoated.... or be really awesome and get it nickel plated.
fasted58
fasted58 HalfDork
6/27/11 4:35 p.m.
Once the correct stack length is found an exhaust shop that does SS should be able to bell the SS tubing end like shown in the OP pic. I've had exhaust tubing belled (and then flattened) into a flange mount to mate w/ header collector flanges instead of welding on tubing collector flanges.
44Dwarf
44Dwarf Dork
6/28/11 8:54 a.m.
http://www.stanford.edu/group/prl/documents/html/spinning.htm
henrryknight
henrryknight
7/8/11 6:25 a.m.
thanks its a good one i have never seen.
http://www.metal-supplies.com/12201/index.html
Taiden
Taiden HalfDork
7/8/11 7:59 a.m.
I would LOVE to try metal spinning... but be careful, because if the work lets go it will slice through you like a deli slicer. Serious business, that metal spinning!
2002maniac
2002maniac HalfDork
7/8/11 12:38 p.m.
I made my own once upon a time. I turned a mandrell on a Cnc lathe with the proper radius, greased up my tubing, and used a shop press to do the flaring. Stainless would be tough if it got work hardened though.
Taiden
Taiden HalfDork
7/8/11 1:01 p.m.
http://www.youtube.com/watch?v=um-biLfru-c
stafford1500
stafford1500 GRM+ Memberand New Reader
7/8/11 2:24 p.m.
try Kinsler if you want it without spinning your own.
I have seen an austrailian poster suggest using egg cups that had the right shape. You might be able to find something similar in a kitchen supply store. They would generally be stainless, but you might have to do some other fab work.
I suggest for the development stage, you make the shortest stack you can, with a seam in the middle and then you can make straight sections of tube to fit in the middle for length tuning.
Bgf7XtJfP6b9aR5Tbuzup61VxwaUyVBTNjVCimqs2lA006dztE8zEBO9PN8cjm0A
