dculberson wrote:
This thread got me as I just replaced the plugs on my turbo Volvo 850. All 5 plugs were gapped wrong according to the measurement on the box. Turns out the box marking was incorrect and I gapped the plugs wrong. Huh. Car's running great. Factory calls for .028" and I gapped to .035". Should I re-gap or leave it at the higher gap?
If you're not getting misfires, I'd leave it.
Bench Racer (BowtieBandit) wrote:
Why do people assume that all spark plugs are pre-gapped?
/rant.
I gapped a set of platinum plugs with a feeler gauge, ran ok then ran like poo after a few thousand miles. Parts man said "Platinum's are pre-gapped, you ruined them"
I recall reading something about platinum plugs being sensitive to feeler gauges, and if you are going to gap them only to use a tool which does not scrape the Pt surface. As I really only have ramp or go/no go tools, I just stuck them in as is. Actually I prefer copper plugs which I habitually check the gap on.
I'm assuming that's where it originated, better to run the pre-set gap on fancy metal plugs than risk ruining the precious metal surface treatment with a ramp style feeler, thus pre-gapped, or don't touch it.
Thanks, I'm not, so I will leave it, unless something goes wrong!
