93EXCivic
93EXCivic MegaDork
8/27/14 8:14 p.m.
 I removed the pedals and master cylinder brackets tonight. I am assuming that the bracket area has been modified and that the metal on the body was bent to make room for a different brake master cylinder.
wvumtnbkr
wvumtnbkr GRM+ Memberand Dork
8/28/14 3:45 p.m.
Do you have some sort of attachment to this car?
The reason I ask is because it seems like a ton of work. You are rebuilding the engine. Rebuilding the suspension. Rebuilding the chassis. Rebuilding the body.
Why not just start with a different car?
I understand that the build can be more fun than any other part, this one just seems a bit scary!
Good Luck!
93EXCivic
93EXCivic MegaDork
8/28/14 6:50 p.m.
In reply to wvumtnbkr:
Well I like the early Spitfires the best and I got this one for free. It has racing history. And any Spitfire would end up getting torn down to this level any way. The suspension and a lot of other components just aren't strong enough for racing in a Spitfire so any of them would end up a bare frame .
Admitted the body is really bad but hopefully I can find a parts car with a better one.
oldtin
oldtin UberDork
8/28/14 7:47 p.m.
Doesn't look much worse than the TR4 I started with. I've made 70 some odd patch panels and took it down to a bare frame for a vintage racer build. I did all the body and rocker patching/replacing before I pulled the body off the frame. Can almost see light at the end of the tunnel.
JoeTR6
JoeTR6 Reader
8/28/14 8:41 p.m.
Seeing this thread again makes me glad I'm starting my TR6 with very little rust. OTOH, I'm in about the same place in terms of being stripped down to a bare frame. If you replace the sills on your existing tub, listen to what others have said about bracing the door beams and tacking both sides carefully. I did one side at a time once, and even with bracing and the tub bolted to the frame, it ended up a bit off. If you can find a better tub, it would save a bunch of frustration.
Cool project.
93EXCivic
93EXCivic MegaDork
9/2/14 10:03 a.m.
 Removed the steering rack, steering column, two of the front lower A-arm mounts and the upper a-arm/ shock mounts.  More evidence of racing lots of shims on the A-arms.
93EXCivic
93EXCivic MegaDork
10/15/14 8:28 p.m.
 Let the painting begin.
Ian F
Ian F UltimaDork
10/15/14 9:00 p.m.
Hmm... first time I'm noticing this... why was the frame cut? Wouldn't that add flex to the chassis?
93EXCivic
93EXCivic MegaDork
10/16/14 4:50 p.m.
Ian F wrote: Hmm... first time I'm noticing this... why was the frame cut? Wouldn't that add flex to the chassis?
I have absolutely no idea but I guess I haven't even looked at the frame of a stock one. Cause I didn't notice....
I really need to find a parts car...
Does that cross member just bolt on or is it welded? Victoria British sells the crossmember by it's self.
68TR250
68TR250 New Reader
10/16/14 5:16 p.m.
Hey 93, Have you checked with Matthews in B'ham for a body? There also to used to Merrill's on HWY 278 in Piedmont, AL....might be worth a call.
Ian F
Ian F UltimaDork
10/16/14 8:32 p.m.
In reply to 93EXCivic:
Welded on my cars.
LMbIFFreX9SF7SMGcsIv69d0VDt0ENITb9JbOreyiUUFfiogaey5cKvnn7gGE88Q
