stroker
stroker PowerDork
8/20/23 6:37 p.m.
Is there a simple test to determine if an unknown steel tubing is mild steel or chrome moly?  I'm assuming grinding spark pattern/type?
TurnerX19
TurnerX19 UberDork
8/20/23 9:58 p.m.
In reply to stroker :
Kinda sorta yes....With a fine stone use some known samples for comparison and you will be close. If it looks different than a grade 5 bolt assume some improvement in strenght. Grade 8 bolt is close to 4340, 4130 is the normal tubing chrome/moly. A small sample of 4130 could be supplied, PM me.
ToManyProjects
ToManyProjects Reader
8/20/23 10:37 p.m.
Higher carbon steel should have relatively short, feathery sparks. mild steel will have a longer, duller spark path.
As said, use other known pieces as comparison if you don't already know by eye.
93gsxturbo
93gsxturbo UltraDork
8/21/23 9:43 a.m.
Find a scrap yard with a hand-held spectrometer.  Most big yards have them.
9h2GpNvywPycJgiLi6nJu7ghZlwpMe27SjMn8byDuodcFLkuimYKVFPsurU0fXEB
