96DXCivic
96DXCivic HalfDork
1/22/10 2:40 p.m.
Does anyone know what kind of torque a steering u-joint can withstand before they break?
Nashco
Nashco SuperDork
1/22/10 4:30 p.m.
Not enough information. Continuous or instantantaneous? Nearly straight or at an angle? What rotation speed? If you can find out who makes the u-joint you can usually get specs on it. If you're trying to re-purpose a steering u-joint for a drive application, that's not recommended as it's not what they're made for. You can get really small u-joints that ARE made for drive applications, though, so there's hope.
There are tons of spec sheets on this website to get you started:
http://www.beldenuniversal.com/
Bryce
44Dwarf
44Dwarf HalfDork
1/22/10 6:26 p.m.
no but i know surplus center has some nise one cheap.
https://www.surpluscenter.com/item.asp?UID=2540012218273672&item=1-2738&catname=
Trans_Maro
Trans_Maro HalfDork
1/22/10 9:48 p.m.
[ratrodder]
Just use some 1/2" drive universal joints from your socket set
[/ratrodder]
44Dwarf
44Dwarf HalfDork
1/23/10 7:23 a.m.
1/2 drive unit have no bearings, they'll rust up under the heat and water vapor. Real joints are cheaper too $4.99 with the ruber boot! I bought extra's to keep around. both my dwarf run them.
44
Trans_Maro
Trans_Maro HalfDork
1/23/10 10:44 a.m.
Sorry, I hoped you'd catch the sarcasm in my last post.
I actually saw 1/2" drive universals in the steering of one pos craprod at a show.
Shawn
44Dwarf
44Dwarf HalfDork
1/23/10 12:15 p.m.
Sorry... I've seen "Race shops" use them. Bad idea.
96DXCivic
96DXCivic HalfDork
1/25/10 12:26 p.m.
The U-joints are for a human power four wheel off road vehicle. They are going on the drive axle. Last year we manufactured our own which took up a lot of time so I was looking to buy some this year.
44Dwarf
44Dwarf HalfDork
1/25/10 3:32 p.m.
Even better for the surplus center units. They do several things for you. A) There CHEAP. B) they have both single end units and one with short shaft that fit the single unit. C) There cheap. D) they have needle bearing in the cups. E) there cheap
kb58
kb58 Reader
1/25/10 4:53 p.m.
Seriously, sounds like the wrench U-joints are just the ticket, assuming this is for some sort of FSAE Baja thing that'll be driven one day. Don't expect them to last, and don't underestimate the shock loads. They'll do okay if you can keep the angularity low
Trans_Maro gets points for thinking outside the box...
96DXCivic
96DXCivic HalfDork
1/25/10 10:27 p.m.
Cost is no problem and they do have to handle high loads.
Trans_Maro
Trans_Maro HalfDork
1/25/10 10:51 p.m.
Have you checked a farm supply?
They usually have small u-joints in both splined and weld-on fitting in various sizes.
They're farm implement parts so they have to be cheap and take a E36 M3 kicking.
Shawn
96DXCivic
96DXCivic HalfDork
1/25/10 10:54 p.m.
Brilliant. I will do that.
SYx5czAQ4hhAjJobI0hiepcMa35zfCXr4SgCycDivmcyMMJMXx6MyZ1h5MNAGtea
