87 Scirocco 16v, so reverse flow obviously.
Book procedure for refilling coolant says fill, run to temp, cool off, top off.
Shade tree ways is the same, but it says fill, add while running untill almost at operating temp, shut down, allow to cool and top off.
Both of these cause overheating immidately.
I found in an act of desperation, squeezing the upper hose forces huge amounts air. Keep squeezing and adding coolant until it stops popping significant bubbles.
Car runs under temp while moving, a bit warm while running still. System seems to work, if maybe a thermostat staying open.
I think I found the reason to why I'm getting air in the system. A coolant flange off the head is contacting a serp belt tensioner I added from a different engine. It seems to have rubbed a hole in the side of a coolant bypass hose. Kinda weird in that its seeping coolant and allowing air in, but how its rubbing the tensioner, the pressure applied to the hose keeps it from just blowing completely.
It just seeps coolant and aerates the cooling systems, ok at least I figured out where the coolant air is coming from.
But why would this manual priming of the system allow it to be semi functional, while the normal ways of bleeding air don't seem to be doing anything.
I have a new coolant flange with a different offset so it won't contact any longer and a new bypass hose, but what would make the normal way of bleeding fail so badly? Keep in mind the hole found on the hose is pin sized.
