I'm doing the timing belt on my brother's 2009 Accent Monday. Is the crank pulley belt reverse or regular thread and should I change anything else while I'm in there. It looks like the water pump is external so that shouldn't be a problem.
The last Hyundai I did a timing belt on was normal CCW to loosen.
Be careful with brittle Korean wires and connectors. Use a pocket screwdriver to lift the tab from the end of the connector instead of the stupid "button" tab that never works where applicable.
