stroker
stroker PowerDork
3/7/24 3:17 p.m.
Has anyone tried to put a Boxster engine in a 914?
3/7/24 3:21 p.m.
Renegade can put a Boxster transaxle in a 914.
Rodan
Rodan UltraDork
3/7/24 5:00 p.m.
californiamilleghia
californiamilleghia UberDork
3/7/24 6:08 p.m.
I like the front bumper / headlight piece ,
Do they still have a headlight height rule ?
rdcyclist
rdcyclist GRM+ Memberand HalfDork
3/7/24 6:16 p.m.
"Boy, do you know why I pulled you over?"
earlybroncoguy1
earlybroncoguy1 Reader
3/7/24 7:06 p.m.
I put an SHO V6 into a 912:
adam525i
adam525i GRM+ Memberand SuperDork
3/7/24 10:10 p.m.
More please!
Rocambolesque
Rocambolesque Reader
3/7/24 10:54 p.m.
An old friend of mine had a Boxster engine in a VW Vanagon. I recall he wanted to do the Boxster in a 914 thing. He ended up buying the 914, but I haven't heard from him since.
earlybroncoguy1
3/9/24 11:28 a.m.
In reply to adam525i :
Sadly, it was not meant to be.
While the engine itself fit fine, the upper intake either put the throttle body into the firewall (if rotated forwards), or out through the engine lid (if rotated 180*). The upper intake bolt and intake port pattern is symmetrical, the upper can be bolted to the lower intake either way. I didn't want to cut a hole in the firewall or the engine lid. I experimented with a aftermarket fiberglass Turbo tail engine lid for more clearance, and it would have worked - barely - but I didn't want a huge tail on a '66 SWB long hood body.
I fabricated my own block-to-transaxle adapter from 6061 T6 aluminum, and engine cradle from a hot rod engine swap transmission crossmember. Cooling was going to be a bitch - and again, didn't want to cut holes in a virgin '66 912 body.
I ended up selling the 912 to a guy who planned to swap a Tesla drivetrain into it - but I kept the SHO, cleaned it up, and is now a coffeetable/art piece for my mancave:
moto914
moto914 GRM+ Memberand New Reader
3/9/24 11:42 a.m.
From 914 online discussions: The boxster engine is to wide.
stroker
stroker PowerDork
3/10/24 12:00 p.m.
Thank you!
cHveVBN5v1aLSAi4cdwFT8ce5HEss82o7xwPlzHmxyuVV5WPLp6F3yMGJG1wncMs
