Mr_Asa
Mr_Asa HalfDork
4/5/20 1:37 p.m.
To stave off boredom I'm developing an independent, pushrod suspension for a trailer.  Figure it will give me a good starting place to move to actual car stuff later on.
I've got the static part pretty much figured out I think, I also have a rough FBD and equation from a vibrations standpoint, but how do you figure out the force from a bump in the road?
If the trailer, loaded and everything, is 900-1000lbs, and hits a pothole that is 1" deep, what is that force?  Is the force when it tries to climb out of the pothole worse?
_
_ Dork
4/6/20 1:16 a.m.
In reply to Mr_Asa :
For every action there's a reaction. Same force up as same force down. Unless, you have a shock absorber keeping the shock from "boinging" back as hard.
stafford1500
4/6/20 5:54 a.m.
The forces on the back side of a pothole are worse, because you have the mass of trailer accelerating downward as you encounter the back face. The front of the pot hole is basically going off a cliff. Use a factor of safety of 1.5 for most anything you come up with load wise since we cant all figure out every situation.
My initial thought on a worst case loading would be something like a 4x4 in the road that the trailer encounters. Anything bigger and you probably have other issues.
Mr_Asa
Mr_Asa HalfDork
4/6/20 7:46 a.m.
In reply to _ :
Sorry, yes, I am planning on having a shock in the system.
Rick O'Shea
Rick O'Shea GRM+ Memberand New Reader
4/6/20 1:58 p.m.
This is a much more complicated than your typical plug & chug equation based solution. You have sprung mass, unsprung mass, tire stiffness, damper rates, friction.... Too much interaction and reactions happening to really crunch it out. What I have done, all the way back to my FSAE days, is assume full vehicle mass on that corner at a 1.5g bump. So for your 1000lb trailer, assume 1500lb into your FBD and then size components from there. Go up in size on hardware for critical joints that take load in multiple directions.
qQjU8fa2mBgptIG9RRWuBdBbkFWByH6KkHA3FVX8gbrIq17wpiBrk5dzHCoWKSDw
