I took this "stretch" (FYI- I work a group of days then have a few off in between AKA "a stretch") off and decided to work on the parts pile that I have gathered for the past 6 plus months to fix the well own DoD lifter problems and I also decided to delete VVT as well.
I started Friday after getting up from a long stressful and underappreciated 12hr night shift in the ED.
First up, just open the dang hood and gaze at the mess I have gotten myself into...
Well, may as well just start taking it apart...
When I had to stop at darkness this was the result...
So the next day continued on with more of the same...
Then an "oops" happened for the good, for once. Yes, the porcelain cracked and broke off and tumbled around in the cylinder for awhile...
Now, we're getting serious..
New camshaft, timing tensioner, valley plate, and timing gear are in... (fishing line to avoid having to fish out the oil pump pickup tube bolt that will fall into the oil pan. GM, you bastards. )
LS7 lifters, LS2 lifter retainers, new timing cover in place.
Ut oh... E36 M3 is getting serious now.
Oops, got ahead of myself and the back 6 studs have to be installed AFTER the head is on the block. Thanks GM for the 1/2" firewall protrusion for that. Only took 4 tries to figure that one out...
Closer.... Even after straining a muscle or three trying to torque the ARP harmonic balancer bolt down to 235 ft/lbs.....
Not many parts left in the pile to put back on now...
Like I said fast work after the valve covers go on and exhaust manifolds are bolted on...
Finished!!!
Filled it up with coolant, no leaks, went for a test drive... The TrickFlow cam I chose was kind of mild anyways, but damn, it's like stock. Oh well, if the turbo kit I want ever gets procured, it will be 730RWHP of awesomeness!
TL:DR- I took SWMBO's DD Suburban apart, put it back together with decent parts, even some performance parts, and ended up disappointed with the results.
