Sure thing-- probably the easiest thing to do is hit up www.megasquirtpnp.com and download one of our basemaps we setup for the MSPNP's. The three models that are out now are MS1/Extra based and all fire up and warm up well.
In general though, I'll find what my hot cranking PW's are, and then starting working down in temp from there. It's easiest to tune the hot PW's, and you know it will need a bit more as it cools off, so I'll scale the PW up as the CLT temps drop, and then look for opportunities to fine tune it when the car is at those temps (or make opportunities). Keep in mind it's probably better to er on the lean side at first and slowly add cranking PW until it starts to catch. If the car doesn't fire up easy because there's not enough fuel, no problem, you get another chance. If you get carried away and add too much you can flood it and then need to clear the cylinders before trying again. Best to start lean and add fuel till it catches.
So... first discussing ASE and WUE from the perspective of having a hard time getting the car to start and run, and then from the perspective of tuning them properly....
Afterstart Enrichment (ASE) -- If you cranking PW's are close and the car pops off, but then immediately, or very quickly dies, your ASE is likely the problem. ASE adds extra fuel just for a few seconds, or in some cases a set number of engine cycles, after the engine starts. You can watch in the tuning software when ASE and WUE (warmup enrichments) are activated. Starting a car goes like this...
You turn the key. The ECU will show it's in cranking mode. It determines this by the fact that it sees RPM, but that RPM is below a set speed (generally about 300 rpm).
Once the engine pops off and RPM goes above that speed (300rpm in this example, it's configurable though) four things happen. Cranking mode is off, Running mode is on, ASE is activated and adding extra fuel, and WUE is activated and adding extra fuel.
ASE like I said above lasts a few seconds, maybe as long as 30 seconds. WUE lasts until the engine is up to a set temperature, usually 160*F or so. (also programmable).
If the car fires, and then dies, and your VE table is at least in the ballpark, then ASE and/or possibly WUE are likely the problem. They work together. So if the fuel commanded by the VE table is your baseline, and WUE is adding 25% because the engine is cold, and ASE is adding 15% because the engine just started, then you've got 140% of the normally commanded fuel being squirted during those first few seconds while both ASE and WUE are active. That may or may not be enough.
Usually, if the car is popping off, but then dying immediately (not even really trying to run), then you've got too little fuel, or possibly WAY the heck too much, but usually too little. Try increasing ASE in the temp range you're at and see if it improves.
If the car pops off, runs for a few seconds, you see the ASE indicator turn off and right then the car starts running rough or dies, then the WUE needs to be adjusted more than likely. That's telling you that with WUE and ASE active there's enough fuel at that temp range, but as soon as ASE turns off, there's not enough fuel even though WUE is still active, so you need more WUE.
Now... the above is just one way to help you get your car started in the first place. You will not be able to fine tune WUE or ASE until the VE table is tuned well so if you start out this way to get the car running, after you dial in your VE table you'll revisit ASE and WUE. This is not a hard thing to do unless you neglect to do it and then get frustrated that it didn't just tune itself. Most gearheads armed with a wideband o2 could tune their VE table fairly well with the software and tools provided. Ignition takes a dyno to really do right, the hardcore DIYers have some other methods, and/or just copy somebody elses map, both of which can be risky of course All that said, a quick dyno session on a steady state dyno will sort out your VE and Ignition base maps nicely and give you a very nice running motor. Costs a few bucks, but then your car runs right. Very right.
Once the VE table is tuned though tuning ASE and WE is pretty easy. You just start the car when it's cold, with a wideband, and watch it come up to temp slowly idling. As it hits each temp range that's available to tune in the Warmup Wizard, you adjust the WUE enrichment for that temp range, let it warm up to the next range and adjust it, etc. I shoot for mid 13's here usually. Then the goal with ASE is the same thing and is even easier, watch it when you start the car at different temp ranges, and adjust to target the AFR's you want to see right after it starts.
So in order.... get it started. Tune VE. Tune WUE. Tune ASE.
Generally speaking, a newer, more efficient, multiport engine with the injectors very close to the ports and atomizing nicely, will need less ASE and WUE.
A TBI engine will likely need much more ASE and WUE.
A IRTB engine will probably be somewhere in the middle of the two.
This has alot to do with the fuel having to flow through manifold with the air longer distances, and on a cold engine more of the fuel tends to fall out of the airstream, so you have to throw more fuel at it to compensate.
