dannyp84
dannyp84 Reader
5/6/22 10:25 a.m.
Last week I was ready to test start my Montero, (I have a "build thread" on this but I haven't been good about updating it - https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/91-montero-refresh/183386/page1/ - after replacing the block with a new old stock short block and then fitting it with reman heads. The factory oil pressure gauge has never worked reliably, so I wasn't going to count on it during the test start. After spinning the motor by hand to make sure it spun freely, I started and ran the engine just long enough to verify that it was in time and running correctly. Then, I shut it off and cracked the oil filter loose to see that the oil pump was sending oil there, and I got a stream of oil from the filter when I loosened it, so that's a good sign (I think). I've only run the engine for a matter of seconds so far, because it took me so long to rebuild this thing and I don't want to wipe it out in the first minute.
I found this: https://www.summitracing.com/parts/sum-899004 - which I could theoretically plumb into the NPT fitting where the oil pressure sending unit usually resides. Should I pick up one of these test kits with a long enough hose to read the gauge from inside the vehicle, and trust it to give me an accurate oil pressure reading? Is there anything else I should keep in mind? This is really my first engine overhaul, and though I replaced the heads and put everything back together, I honestly couldn't tell you the process by which oil flows from oil pan to overhead cam. This project has been a real learning experience and I'm hoping to not turn it into a sad ending.
Robbie (Forum Supporter)
5/6/22 10:35 a.m.
You can also just get any old super cheap oil pressure gauge and plumb it in.
On a brand new engine (or any engine that hasn't run in a long time) I'd be tempted to disable spark and fuel - even removing the plugs maybe - and spin the engine on the starter until I saw oil pressure on the gauge.
If you see oil pressure on the starter, you should be fine to run the engine and make further checks.
5/6/22 10:39 a.m.
For example the middle gauge in this. You can probably find them for $10
https://www.harborfreight.com/automotive/automotive-accessories/interior-accessories/electronic-triple-auto-gauge-set-41017.html
eastsideTim
eastsideTim PowerDork
5/6/22 11:04 a.m.
And if you don't want to risk using an HF gauge, I suspect most local parts store will stock a cheap Bosch or other brand name mechanical gauge, and they are usually only around $20.  I use mine to test with, but then use electrical gauges in the car once I've verified it with the cheap mechanical one.
Sonic
Sonic UberDork
5/6/22 11:27 a.m.
Agree with the suggestion to pull the plugs and disable spark/fuel and spin the engine on the starter to get oil pressure.  I also do this with new motors and even swaps and wham adding something like an oil cooler.
dannyp84
dannyp84 Reader
5/6/22 6:48 p.m.
Good idea disconnecting the ignition before testing. I called a friend and he had the oil pressure test gauge with a 4' line, so I can watch it from inside the truck. If the rain ever quits I'll hook it up this weekend and give it a shot.
zLMkVOCDL1jAtFr4muJ5Fpe1mkyVdSveN2JZbXbRYtUnkKB8maxM7EFAM58JPeJ8
