Big update weekend!
Grill header finished
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/012.JPG)
The grill header panel is finished and reinstalled. The driver’s fender needed a little tweaking (it’s the damaged one) so it could go on how it’s supposed to. It feels good to put stuff back ON the car instead of taking it off!
Coolant system rebuild time
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/015____.JPG)
I also managed to start the coolant system rebuild. The old coolant actually looked really good! Drained this out, removed the heater hoses, crossover hose, and the radiator hoses. All of that will be replaced with new stuff (Goodyear, natch) as well as the thermostat and radiator cap.
While you're in there...
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/024_.JPG)
I have a seriously bad habit of going “while I’m in here” with this car… I also took out the fan and shroud for a little clean-up. I might even replace the fan. The radiator works great and is all copper, so I’m not going to mess with that, but the v-belts are getting changed.
Keep taking stuff apart!
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/025.JPG)
Now I’ve got some good access to the front of the motor. Obviously I need to do some cleaning and painting in here! I might also change the water pump, we’ll see. I’d really like a new harmonic balancer, too (I’ve seen a stock one fail, and it was not pretty!). All of this was pretty necessary to get to the fuel pump and hard lines, which are all getting changed as well.
Problem found
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/023__.JPG)
Since I was already there I decided to pull the original 55 amp alternator out. Turns out it has a broken wire on it! Luckily I happen to have a spare GM-style 1-wire 100 amp alternator from a Wagoneer that will bolt right on…
Weight savings
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/016_.JPG)
The front plate mount was large, steel, mangled, rusty, and heavy, none of which are desirable qualities. Since my state only requires a rear plate on classics, off it comes! Much cleaner and lighter.
Roof primer is holding up
![](http://grassrootsmotorsports.com/media/img/readerrides/updates/2012-04-22_20-13-54_327.jpg)
The roof primer is holding up well. There’s no bare spots or rust besides a little trickle where the quarter panel lead seam is. Good! My protection plan is working. You know, I can’t stand the cheap roof rails modern cars have. I love the older cars 1-piece rooflines like this, it’s just so much better looking. Can’t wait to paint it!
