1 2 3 4
Ian F
Ian F PowerDork
8/19/13 10:46 p.m.
When I was 19 my DD was a '78 F-150 4x4 pick-up with a large cap on the bed. The cap was a wood-framed, aluminum skinned affair with a door on the back and one odd feature: it was about 12" taller than the cab and dead-square to the oncoming air (instead of rounded like most caps you'll see). We used it to haul our band gear and friends to various hard-core punk shows in the area. I installed a pass-thru so people in the back could talk to us, but the height of the cap deflected air down and past the seal.
My solution: take a piece of plywood and some brackets made from 1" angle to make an air deflector that I screwed into the top of the cab. I'll ask my old bass player if he ever took any pictures of it. It looked terrible, but it did work.
GameboyRMH GRM+ Memberand UltimaDork
8/20/13 7:56 p.m.
Hey you wanted pics? I took the AE92's washer tank home today to repair some places where the tape started to peel and clean out algae that had grown while the car has been in the shop. First time I had to touch it in the probably 7 years since I did the repair.
Didn't get any pics but the pump seal has been replaced with a mighty gob of RTV. Here's the crack that the tape is holding in:
Repair's already done and I think it'll last another 7 years. I'll have to get a pic of the Samurai's washer bottle tomorrow.
Swank Force One
Swank Force One MegaDork
8/23/13 6:06 p.m.
Not mine.... but just found this on another site:
corytate
corytate SuperDork
8/23/13 7:49 p.m.
Swank Force One wrote: Not mine.... but just found this on another site:
is my actual face right now
M2Pilot
M2Pilot HalfDork
8/23/13 8:02 p.m.
In reply to corytate:
It really took balls to do that.
Knurled
Knurled GRM+ Memberand UberDork
8/23/13 8:23 p.m.
Hmm... i might actually do that to substitute for a bumpstop.
Sal_the_man
Sal_the_man New Reader
8/23/13 9:55 p.m.
In reply to M2Pilot:
ROFL.
corytate
corytate SuperDork
8/23/13 10:08 p.m.
M2Pilot wrote: In reply to corytate: It really took balls to do that.
this needs to be in say what? next issue! lmao
it'd be perfect with absolutely no context
petegossett
petegossett GRM+ Memberand UberDork
8/23/13 10:39 p.m.
I can just imagine what would happen when they bottom that car out across a RR crossing, speed bump, whatever, and a dozen tennis balls come exploding out from behind the vehicle.
Sure hope there's no one following close behind on a bike though.
motomoron
motomoron Dork
8/23/13 11:30 p.m.
In reply to Giant Purple Snorklewacker:
That's not ghetto. That's rad as berkeley.
aussiesmg
aussiesmg MegaDork
8/24/13 7:36 a.m.
novaderrik wrote:
nicksta43 wrote: Not something I've done but I found it while trying to bleed the brakes. Someone took an 8p nail and stuck it into the rear circuit in the master cylinder instead of replacing the rusted through hard line on the rear axle
that's just dumb. it's easier to just flatten the hard line before where it rusted thru and roll it back on itself so it doesn't leak.
I, eventually, found this on the Expedition after I replaced the rotors, pads and rear lines, then damned if they wouldn't bleed.
Wally
Wally GRM+ Memberand MegaDork
8/24/13 9:31 p.m.
I went under the back of the Cavalier to look at an exhaust leak. Turns out there isn't much of anything but paint from the doors back so it made no sense to replace the exhaust. I cut a piece from a tomato paste can and secured it with JB Weld and some hose clamps. The car is silent once again.
44Dwarf
44Dwarf SuperDork
8/25/13 6:38 a.m.
My 1st engine transplant was a sb350 in to a Monza coupe. After buying the elephant ears engine mount kit and a funky shaped Milodon oil pan and pick up. There was no $$ left for a 17 year old to buy and exhaust system. Custom header place quoted $1400! So.....Flex pipe to the rescue. The Pittsburg seamed type. The whole system was flex pipe, to hold section in place I used hose clamps and coat hangers run along the sides. It worked long enough to pass inspection....the junk yard motor last only a bit longer then that....lost timing chain at red line...
ebonyandivory
ebonyandivory HalfDork
8/25/13 12:25 p.m.
Knurled wrote: We got a winner. I said... we got a winner!
Mother of Berk, is that Cosmo Kramer?
ebonyandivory
8/25/13 12:35 p.m.
My friend in high school had a '79 Grand Prix with a Quadrajet. It used to stall at stoplights. When it did, he'd pop the hood, run to the side of the car and carefully replace the nickle he had perfectly wedged in the carb to keep it running.
He never showed me how he did it. Like it was the secret recipe for Bush's Baked Beans or sumthin'.
1 2 3 4
jFWTh0ab1CDqJ7FTqNkORQVS7i5lYCdvhsbq34dzAjHY7Vz7F0hpTPjsu1FCE7c5
