TunaDad brags (rightly so) about his post-divorce (circa 1990-1995 or thereabouts) race setup. For right at five thousand dollars, he got an old F150 (which he named FUBAR long before we knew that was an acronym), a trailer, a 1969 AMX, a 427 chevy with worked iron heads and a bunch of compression, used and old junk for everything, and ran something in the high tens and did very well in the local brackets. More money and time with the combination eventually brought the same car into the mid-high nines, though the transmission changed from a TH400 to a powerglide, giving up a bunch of ET in the name of consistency (one shift versus two).
I don't have five grand. I also really don't like the idea of a dedicated drag car which can't be driven on the street.
With the advent of Gen III/IV GM engines, and cheap good (non ebay) turbos, it seems we could do better for the same or less today. What's your recipe at the same pricepoint? If you don't like that, what's your less expensive recipe for tens?
Aerodynamics count, as consistency is the name of the game. As such, I'd pick a more modern car, probably a Celica Supra or a FC RX7. Smaller is no good, because wrenching in the pits needs to be easy. I'd back half it though, and leave the front alone.
I'd go with an iron block 6.0 gen III with an intercooled borg warner turbo (no idea which one) on E85. If I was going drag racing only, I'd skip the intercooler and run an icebox for the intake air.
Not sure what needs to be done to the engine to hold how much boost, but 15 psi on an otherwise stock output 6.0 should get enough horsepower in that body to be in the tens.
I'd probably end up with the same truck and trailer off of Craigslist that he did. No fair skipping this for street driven stuff, though, because drag racing breaks cars enough that you need a ride home, plus a place to keep the cooler and the tools.
Your turn.
