Mr_Asa
Mr_Asa Dork
7/16/20 4:37 p.m.
I can't get any damn purchase on it.  Been using picks and all sorts of similar tools.
I'm almost at the point where I am going to cut it out and buy a new one for $10
Most the ways i can think of might damage it.
An easy out that size?
Couldn't tell if the shaft goes all the way through the part, was guessing it didn't.
Another SWAG... a concrete expansion bolt/anchor.  Bottom it out, tighten the nut til it grips, pull it out.
jharry3
jharry3 GRM+ Memberand HalfDork
7/16/20 4:55 p.m.
What is that? It doesn't remind me of anything on a '67 mustang.
Can it push through the other side if you had a sleeve that matched the inner diameter of the casting  hole?  Then just hammer it out.
  A sleeve and "C" clamp would do that if you don't have a press.
Mr_Asa
Mr_Asa Dork
7/16/20 4:57 p.m.
Swivel bushing on an old outboard.  #78 on here
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1961&hp=40&model=35525&manufacturer=Evinrude&section=Exhaust+Tube+And+Swivel+Bracket
Definitely can't push it through, there's a lip on the inside.  You almost have to hook onto it somehow and pull it.
Jesse Ransom (patron dork)
Jesse Ransom (patron dork) GRM+ Memberand UltimaDork
7/16/20 5:00 p.m.
Don't suppose it's a size where you could find a nice-fitting slug, put some grease in there, and hit the slug with a hammer?
I really need a lathe. And so, apparently, do you.
L5wolvesf
L5wolvesf Reader
7/16/20 5:03 p.m.
I imagine those are 2 different materials so I would try soaking it in some sort of penetrant at least over night. Then try to first get it to move one way or the other.
Mr_Asa
Mr_Asa Dork
7/16/20 5:05 p.m.
I do have a lathe, actually.  Haven't had a chance to set it up though.
Do you mean like how you can get a pilot bushing out by putting grease behind the bushing and push in an alignment tool?  If so, its completely open on the other side and there isn't enough of a lip to get a plug to seat.
Mr_Asa
Mr_Asa Dork
7/16/20 5:08 p.m.
I can pry it up a little bit and spray stuff under it, doesn't reach all the way back though, maybe 1" out of the 3" length?
1988RedT2
1988RedT2 MegaDork
7/16/20 5:13 p.m.
What's it look like from the other side?  Is it two pieces with a lip in the middle?  Can you use a long punch and drive each piece out from the back?
jharry3
7/16/20 5:13 p.m.
I could not find the exact one you need but YouTube has a lot of videos on how to disassemble these outboards.
7/16/20 5:16 p.m.
What about a pilot bushing puller? Its essentially a spreading hook pair attached to a slide hammer. Rentable at o'Reilly
Mr_Asa
Mr_Asa Dork
7/16/20 5:19 p.m.
In reply to 1988RedT2 :
There are two bushings, a top and bottom.  The top came out with a bit of effort, but this one is being a butt.  From the other side it is too long to really get anything aligned with the lip
Here's what just the bushing looks like https://www.ebay.com/itm/NO-BOX-OMC-Evinrude-Johnson-Bushing-Part-305265/333254936356
Mr_Asa
Mr_Asa Dork
7/16/20 5:21 p.m.
Maybe?  The diameter those have to work with is pretty well aligned with this size, but the lip is almost nonexistent.  With the pick shown in the first post I actually have to force it into the lip.
eastpark
eastpark HalfDork
7/16/20 5:26 p.m.
If a new one is $10.00 then cut that one out. It's not worth your time to keep messing with taking it out carefully.
edit: Shotgun?
Mr_Asa
Mr_Asa Dork
7/16/20 5:30 p.m.
In reply to eastpark :
Im leaning towards it.  I did realize that the ebay link I posted above is a guy over in Clearwater, just across the bay.  I may just drive over and get one tomorrow.
L5wolvesf
L5wolvesf Reader
7/16/20 5:32 p.m.
In reply to Mr_Asa :
The eBay pic looks like plastic. If so I suggest a Dremel to get your . . . Johnson bushing off.
MrFancypants
MrFancypants Reader
7/16/20 6:34 p.m.
I'm lazy so I'd cut a couple of notches in it and pull it out with pliers. It's not worth being gentle if a replacement is only $10.
Mr_Asa
Mr_Asa Dork
7/16/20 7:02 p.m.
I took a crappy chisel to it.  She's out.
Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
7/16/20 8:41 p.m.
With a plastic bushing this wouldn't be necessary but for metal sleeves that have at least a ~0.4" ID i've often used a jigsaw to cut slots through the sleeve. Sometimes one is enough if you can catch an edge and cave what's left in towards the middle. If not, 2 or 3 cuts and it basically falls out.
qnufxarKxfLnxvehspJ0k94fdI7lkVtB1ataKCunDQfye8cLsXAMd2vdfX7iZ6HL
