bequietanddrive
bequietanddrive New Reader
6/5/10 9:51 a.m.
So I know this is pretty newbish but I'm not super handy with a wrench. I've never changed my own spark plugs before, so, anyone have any handy tips for the job?
Luke
Luke SuperDork
6/5/10 10:11 a.m.
When you put the new ones in, start them off by hand, to avoid any cross-threading.
And if you're doing the plug wires, too, change them one at a time, so you don't mix-up the firing order.
gimpstang
gimpstang New Reader
6/5/10 10:26 a.m.
Luke wrote: And if you're doing the plug wires, too, change them one at a time, so you don't mix-up the firing order.
Quoted for truth
Also, buy a tube of antisieze and apply it to the thread before you install. If you ever want to change the plugs again, you will thank me. And don't forget to torque them the spec not just tight.
paul
paul Reader
6/5/10 10:45 a.m.
Adding to the above tips: wait for the engine to completely cool before changing plugs, especially if it's a aluminum alloy / non-iron block!...
NYG95GA
NYG95GA SuperDork
6/5/10 10:54 a.m.
If the plug holes are not very accessible, use a piece of flexible silicone hose, slipped over the tip, to start it into the threads. DO NOT FORCE IT. Once started correctly, use your socket to torque it in.
ignorant
ignorant SuperDork
6/5/10 11:04 a.m.
don't buy cheap plugs.
don't go for gimmick plugs..
motomoron
motomoron Reader
6/5/10 1:09 p.m.
...Righty-tighty/lefty-loosey.
oldtin
oldtin HalfDork
6/5/10 1:14 p.m.
Good variety of extentions, u-joints or flexy extentions are handy for the hard to get to stuff.
poopshovel
poopshovel SuperDork
6/5/10 2:17 p.m.
NYG95GA wrote: If the plug holes are not very accessible, use a piece of flexible silicone hose, slipped over the tip, to start it into the threads. DO NOT FORCE IT. Once started correctly, use your socket to torque it in.
+1. I keep a little scrap piece of fuel hose in my tool kit for this purpose. Anti-seize is a good idea too. Like iggy said, buy good plugs. I'm a fanboi for NGK's.
emodspitfire
emodspitfire New Reader
6/5/10 2:36 p.m.
Co-worker gave me a good tip....(Totally logical sort of a DOH! moment when he told me.)
Always turn the plug the opposite direction (Lefty loosey) to start the threads. When you feel the threads "click" ...the plug threads and cylinder head threads are lined up to start easily. Proceed to rotate the plug into the head.
Rog
hotrodlarry
hotrodlarry Reader
6/5/10 2:40 p.m.
Make sure they are gapped correctly too.
Woody
6/5/10 3:35 p.m.
Use COPPER based anti-seize.
digdug18
digdug18 HalfDork
6/5/10 4:12 p.m.
Don't break them off in the block, their a PITA to get back out. Sorry we're we supposed to post positive tips....
Andrew
ansonivan
ansonivan Reader
6/5/10 4:18 p.m.
Adding to the buy good plugs/not gimmick plugs.
Don't overbuy plugs, the latest tech may not work properly in a 10 year old engine. I've had two instances where bosch platinum + 4 plugs threw misfire codes in bmw s52 engines, misfires went away with a period correct plug.
Another vote for NGK's.
Jensenman
Jensenman SuperDork
6/5/10 5:09 p.m.
Agree on all posted, particularly the 'gimmick' plugs. I've seen platinum plugs cause cold misfires in older type vehicles. I lean toward NGK, Nippondenso and Bosch Supers for engines that don't require platinums and NGK/Nippondenso for those that do.
When tightening the plugs, 'taper seat' plugs should go in hand tight till they stop, then 1/16 to 1/8 turn more with a wrench, NO MORE. 'Gasket' plugs should go in finger tight then a max of 1/4 to 1/3 turn more with a wrench, NO MORE.
Bumboclot
Bumboclot New Reader
6/5/10 6:00 p.m.
Don't buy a pickup with the inner fender liners missing if you live in the rust belt. It leads to the hex of the plug rotting away. My current DD Ranger is like this. I'll probably end up pulling the head.
pete240z
pete240z Dork
6/5/10 8:14 p.m.
coming from a guy with permanent scars on his one arm from a 1986 Pontiac Grand Am SE V6; pay a mechanic.
Grtechguy
Grtechguy SuperDork
6/5/10 8:18 p.m.
pete240z wrote: coming from a guy with permanent scars on his one arm from a 1986 Pontiac Grand Am SE V6; pay a mechanic.
Wuss.....try the back 4 on an Aurora
P71
P71 GRM+ Memberand SuperDork
6/5/10 8:36 p.m.
Wuss.....try the back three on the original SHO.
SkinnyG
SkinnyG Reader
6/5/10 10:17 p.m.
Torque them down 'till they strip and then back them off half a turn.
No, maybe don't do that.
dean1484
dean1484 GRM+ Memberand Dork
6/5/10 11:24 p.m.
By a P71.
maroon92
maroon92 SuperDork
6/5/10 11:45 p.m.
the easiest I have ever done, I did today, the Supra was a breeze to change plugs.
the worst I have ever done were the back three on my girlfriends old Oldsmobile Intrigue.
96DXCivic
96DXCivic Dork
6/5/10 11:59 p.m.
I like denso.
NYG95GA
NYG95GA SuperDork
6/6/10 12:32 a.m.
I generally use Champions, but they're not what they used to be. I'm not sure why.
shadetree30
shadetree30 Reader
6/6/10 6:53 a.m.
If you have an engine with hard-to-reach back plugs, perhaps all you need to do is unbolt the front bolts on the engine cradle and lower it GENTLY, it might be so much easier to do. BTDT on a Rendezvous.
mx4uVymd0k2BvhV6vzq4cUz7rKX5lE3Dj5rNKggbzRjHpoAbOpKWDUDNT7U6rT0W
