Jeff
Jeff Dork
4/24/12 12:23 p.m.
195-55-16 is the stock size for the 02 MCS. Can I run 195-50-16 without issue (I realize the speedo will be off)? What about load rating? The stock is an 87, when I go down to the 50 size, most of the ratings drop to 84 which is about 100LBS less load per tire.
The other option is go to 205-50-16. That's just slightly smaller diameter, but obviously wider. Load ratings are mostly 87. I'm running stock suspension, though I do want to add the Ireland Engineer -1.5 camber tops. Any thoughts on fit? Rubbing issues?
Cheers,
Jeff
DeadSkunk
DeadSkunk Dork
4/24/12 12:56 p.m.
I run my MCS on 205/50/16. I wouldn't worry about load rating at all. Mine don't come remotely close to rubbing with the stock springs.
Ian F
Ian F UberDork
4/24/12 1:14 p.m.
We're running 205/50-16 tires as well. Star Specs on one car, old (NLA) Goodyear GS-D3's on the other. No issues other than it's becoming increasingly harder to find tires in that size.
driver109x
driver109x HalfDork
4/24/12 2:52 p.m.
205/55/16 is a more common size... dont know if that will fit your car though.
NGTD
NGTD Dork
4/24/12 3:13 p.m.
Use this to figure it out:
http://www.miata.net/garage/tirecalc.html
z31maniac
z31maniac UberDork
4/24/12 3:16 p.m.
225/45/16 is another dying size with a few offerings left.
Ian F
Ian F UberDork
4/24/12 7:46 p.m.
driver109x wrote: 205/55/16 is a more common size... dont know if that will fit your car though.
I've seen this size on MINIs. It looks... Odd. 225/50-16 (same o.d.) as well. The o.d. is about 25".
The 24" o.d. is getting hard to find. It's frustrating (an E30 tire is the same size).
amg_rx7
amg_rx7 Dork
4/24/12 9:12 p.m.
205/50/16 on my '06 S on stock wheels
BLfGDllnjkgAWVK8ANDTK9Kwdtdq9fPNSpxOaoGf5tL2JWKk0V8HdV7sazZ8okw6
