eastsideTim
eastsideTim UltimaDork
6/22/24 2:09 p.m.
I may be acquiring a Toyota 3.3 V6 (attached to a rough condition vehicle) at a really good price soon.  A few quick questions:
First, and most importantly, does it have the same issue with oil starvation during high G turns as the earlier 3.0 V6?  I remember the GRM Camry losing an engine or two due to high-ish G cornering.
Also, any easy performance upgrades?  230 HP is nice, but more would be better smiley
Sonic
Sonic UberDork
6/22/24 3:14 p.m.
Basically the same motor as the 3.0 you mentioned, just punched out a bit.  Everyone seems to have moved on to the 3.5 that goes in everything, and has 300 hp.
6/22/24 6:20 p.m.
Yah, the biggest problem with the -MZ engines is the existence of the -GR.
And the ignition coil connectors.  Don't unplug the coils and if you absolutely must, use a pick to lift the lock tab gently over the retaining catch.  You'll still probably break at least 50% of them.
eastsideTim
6/22/24 7:44 p.m.
Thanks!  Sounds like it might not be a performance option, I'll have to decide on the merits of the whole vehicle.
e37BEk4Tt3v5YeRUVhqouLeTMlI2UVLfY7JYCYjRAZg8NifCQuQnWmyoYbtyPMOi
