Feedyurhed
Feedyurhed Dork
3/29/12 4:14 p.m.
I know what it is and what it does. As I get more vehicles and more sets of wheels to go on them I was just curious if all sensors are interchangeable and will work on any car or does each manufacturer have there own system. I already spend half the year with the little yellow light glowing as I swap out summer/winter tires with one set having the sensors and the other one not. I know, I know I should just ignore it or put a piece of tape over it but I have access to some used sensors for cheap and I wonder if they will work on any car. I guess that's another question, do they go bad or lose their accuracy after being used for several years. Anybody know?
DukeOfUndersteer
DukeOfUndersteer PowerDork
3/29/12 4:19 p.m.
They are vehicle manufacturer specific. You can go purchase 4 more to put in your second set of tires/wheels, I think there is a way that the TPS "learns" them.
Cone_Junky
Cone_Junky Dork
3/29/12 4:22 p.m.
Yes they go bad and the batteries also die. Some manufacturers have a recommended replacement interval.
I can usually pull up a predicted battery life with a factory scantool.
Zomby Woof
Zomby Woof UltraDork
3/29/12 4:25 p.m.
You could make up a little PVC pipe with the 4 sensors in it, pump it up to 35 psi, and keep it under your seat 12 months of the year
Feedyurhed
Feedyurhed Dork
3/29/12 4:42 p.m.
Zomby Woof wrote: You could make up a little PVC pipe with the 4 sensors in it, pump it up to 35 psi, and keep it under your seat 12 months of the year
I like the cut of your jib sir!!
Thanks to all who have answered. Ebay has new ones listed.........$40 for a set of four. Guess I will be going with new then.
DWNSHFT
DWNSHFT Reader
3/29/12 6:30 p.m.
ROFLMAO Sheer genius. Best TPMS fix ever.
David
irish44j
irish44j SuperDork
3/29/12 6:39 p.m.
a 1cm x 1cm piece of flat black trim tape on the gauge cluster takes care of any and all TPMS problems.
irish44j
irish44j SuperDork
3/29/12 6:40 p.m.
ROFLMAO Sheer genius. Best TPMS fix ever. David
Jeep guys have talked about this since TPMS came out. Unfortunately, a lot of the sensors now only activate inertially when the tires rotate (and are "off" when the tires aren't spinning), so that trick only works on sensors that are "perma-on" (and yes, it does work).
JLineberg
JLineberg New Reader
3/29/12 8:46 p.m.
I've been told that some are just breaking down the spare tire on their Toyotas and dropping the 4 sensors in there and then pumping it up.
These are the things you learn at the Toyota training facility.
JohnyHachi6
JohnyHachi6 Reader
3/29/12 8:49 p.m.
You should just get another set. I picked up a used set for my GF's RX8. They were $15 on ebay and work great.
Rusted_Busted_Spit
Rusted_Busted_Spit GRM+ Memberand SuperDork
3/30/12 10:25 a.m.
irish44j wrote: a 1cm x 1cm piece of flat black trim tape on the gauge cluster takes care of any and all TPMS problems.
That is what I did.
T.J.
T.J. UberDork
3/30/12 10:32 a.m.
I took my snow tires off the WRX yesterday. Looking forward to not having the light on all the time. I've put like 5,500 miles on the car since I bought it and all but maybe 350 I've had the silly light on.
Ranger50
Ranger50 SuperDork
3/30/12 10:48 a.m.
No the best fix ever is not buying one of these POFS.
Fit_Is_Slo
Fit_Is_Slo HalfDork
3/30/12 6:48 p.m.
Government mandated dude
Feedyurhed
Feedyurhed Dork
3/30/12 10:01 p.m.
Yep. I think all cars sold new in the US since 07 or 08 have them. Sooner or later most of us will have to deal with them.
44Dwarf
44Dwarf Dork
3/31/12 6:53 a.m.
From what i've read this will not work. they need to spin 2-5mph to close a light weight fly switch this is why light blinks when you 1st start the car. It's the way to save the battery inside the sensor.
petegossett
petegossett GRM+ Memberand UltraDork
3/31/12 7:14 a.m.
In reply to 44Dwarf:
Duct tape them to the CV shaft?
DWNSHFT
DWNSHFT Reader
3/31/12 4:21 p.m.
TPMS was mandated on all passenger cars in the United States beginning in 2010.
David
erohslc
erohslc HalfDork
3/31/12 4:31 p.m.
Considering how many folks have been injured/died because their tires were low enough to be dangerous, but not low enough to get noticed, it's probably the most sensible, cost effective thing NHTSA has ever mandated.
example: 5 MPH bumbers vs TPMS.
And for those that wish to do so, $.01 worth of black tape to disable.
1ZdbS3BJzbS88wwbWhu0HPFnSnhR8rekz5FWS626VdTlbQnWep91xssTbcfR9m3P
