stan_d
stan_d Dork
5/15/13 6:08 p.m.
I bought someone else's home built trailer. And with a small load it rubs the tires. The springs don't appear to be sagging but there is less than 2" of clearence above the tires. How much should it have ?
codrus
codrus GRM+ Memberand Reader
5/15/13 7:17 p.m.
Flatbed? Enclosed? Cargo trailer? What size? What do the tires rub -- the fender?
Pics would go a long way here. :)
DeadSkunk
DeadSkunk SuperDork
5/15/13 8:12 p.m.
Enough to let the axle hit the frame before the tires hit the fenders.
carguy123
carguy123 UltimaDork
5/15/13 8:14 p.m.
What's your tire pressures?
stan_d
stan_d Dork
5/15/13 8:46 p.m.
Flat bed and yes they rub on fenders on the way back from the challenge wore tread off both front tires. When the tire contacts it there still is 5" before the axel would hit the frame.
Time to fab up some removable fenders then. Thanks.
5/16/13 5:52 a.m.
Connect the fenders to the axle, not the frame. They will then move with the wheel and also give you more door-swing room.
DeadSkunk
DeadSkunk SuperDork
5/16/13 6:02 a.m.
5 inches is a lot of travel for axles. Are the springs soft enough to actually allow 5" of movement? If not, you won't need that much gap between the tires and fenders. The removable fender idea is a good one for loading low cars. I used to have to climb out a Miata window. Not easy.
iceracer
iceracer UberDork
5/17/13 5:24 p.m.
Put bump stops on the axle/frame.
5/17/13 5:27 p.m.
can you raise the fenders any? Also, how much does the trailor "sag" under load?
stan_d
stan_d Dork
5/17/13 10:55 p.m.
I am going to raise the fenders there is 1 " above the tires empty. The springs are still in consideration for replacement.
TRoglodyte
TRoglodyte Dork
5/17/13 11:04 p.m.
Air bags , air shocks. adjustable comfort.
FranktheTank
FranktheTank Reader
5/17/13 11:17 p.m.
Lower profile tires... Y'all are over thinking. Or weld a piece of square stock with mining belt bolted to the top after putting the whole thing on jack stands.
N2SC19QbqVeJS2MSaRS0SHpnL7XMPfu8G8aNH97XN58FbjR9sql1ciHNQPdziC19
