Are these unobtainium / expensive.. .. .. or both?
I found a killer deal on a car but the trans is junk. I have not looked / called around yet as I am at work but the car can be had for under challenge money. If a trans could be had for in the $500 range it may be a worth while project.
I doubt the trans is the only thing that is junk.
For the price I can get it for I can part it and make $$$$ The motor is supposed to be fine. I actually suspect a clutch or a master or slave cylinder have gone and it is not the trans at all.
The car was driven by guys daughter that could not get the hang of driving a standard. So yes the trans could be the problem but most of the time when people don't know how to drive standard they kill the clutch.
Either way I am interested but worst case if a trans is bad and it is 1k then forget it.
A quick search of car-part shows a range of $660-$6500, most between $1000 and $1500.
Here u go...whole car for $1k. Grab tranny and part the rest...
http://raleigh.craigslist.org/cto/3422056683.html
If it doesn't specify on tranny, it's probably the tiptronic. Manual 2.7T A6s were moderately uncommon.
As regards that ad above -- if it needs one turbo, then it needs 'em both. As soon as one fails, the other one tries to compensate and that blows it up too.
docwyte
HalfDork
11/20/12 12:03 p.m.
Well, not only that but it's so much damn work to replace a turbo on that car that you'd be a fool to not replace them both at the same time.
