Mazdax605
Mazdax605 HalfDork
7/9/10 10:01 p.m.
Hey guys,
Tonight while driving my 74 RX-4 it got stuck in 3rd gear,and will not come out. About two months ago another transmission(79 RX-7 5-speed swapped in by PO) got stuck in 4th gear. I pulled that other transmission out because it was noisy even before it got stuck in gear,and replaced it with a spare 79 RX-7 transmission I had around from a parts car. The transmission in it now was in unknown condition,but so far it had been working just fine. I replaced the clutch slave a few weeks ago,and the clutch master today before taking it to the local cruise night,and then to play hockey when it failed. When I pull on the shifter it has a really strange pulsating feel to it,and will not budge. The clutch system is working,and I limped it home in third gear which is no small feat considering the lack of torque from the spinning triangles. I was driving like an old lady when it happened both times,and not winding it up real high,or shifting fast.Any ideas why the transmissions keep getting stuck on me?
Chris
Jensenman
Jensenman SuperDork
7/10/10 7:58 a.m.
A 'pulsating' feel in the shifter tells me something in the tranny is misaligned, probably the 'slider'. That's probably due to just plain old wear. The early (79-80) RX7 trannies also had a shift mechanism different from the 81- up and that could have something to do with it as well.
If you can't find another early 7 box, the later type shifter can easily be moved forward ~4" so the shifter will come out of the RX4 floor pan opening. I've done three different ones so far. This page has instructions on how to do it: http://the-mite.com/mite18.htm This is done on a Miata transmission but the RX7 works the same way. By the way, I removed the tailshaft housing from the first one I did, but that's not necessary. It can all be done with the tailshaft housing still on the box, you just have to be careful not to get any drill/grinder 'fuzz' in the hole where the shift rod comes out.
44Dwarf
44Dwarf HalfDork
7/11/10 7:59 p.m.
I might have a box from a 12a but might have tossed it last year when scrap was up.. I'll take a look monday.
If it there you have to come pick it up in winchendon ma
Mazdax605
Mazdax605 HalfDork
7/11/10 8:18 p.m.
It will need to be a 79-80 trans Dwarf as the later 81-85's have the shifter in a different location. Also it could be a pre-RX-7 trans as well,but those are tough to find. I have one,but no bell housing so it is sort of useless.
Chris
fastmiata
fastmiata Reader
7/11/10 8:24 p.m.
Until I learned to have someone knowledgeable ie ISC to rebuild my trans for the RX3, we broke a trans every 2-3 races. The early trans were not up to the stress of racing or other hard uses. I can remember buying complete cars just to get to another trans. Once I started having the trans rebuilt, I never had the issue again. And yes, the shift forks over-rotate.
Mazdax605
Mazdax605 HalfDork
7/11/10 8:51 p.m.
The thing that kills me is that I wasn't beating on the car either time this happened. I could understand it if I were beating on it,and ham-fisting the shifter,but I wasn't. Can I break the tranny apart,and fix this issue cheap enough,and put it back in,or am I better off just getting another used transmission?
I am tiring with this car. Thing is I bet I can't sell it even with a good transmission.
2OIp48lkSxYx3TwQ3eKsN4qdXLisf146cdluGXHJombvGARV6fESf64bEwTQeMB4
