1966stang
1966stang New Reader
9/25/11 11:50 a.m.
Do any aftermarket roll bars fit with a factory hard top?
2002 model year car....
And...
What is the best way to put a limited slip in these? Planet Miata wants a thousand bucks for a limited slip rear end...is there an aftermarket solution that's better?
Car is used mainly for autocorss, not worried about classing....
dyintorace
dyintorace GRM+ Memberand SuperDork
9/25/11 11:57 a.m.
These guys offer hard top compatible roll bars. Look at the right hand column on this page.
http://www.bethania-garage.com/why.htm
speedbiu
speedbiu Reader
9/25/11 12:44 p.m.
Heres a rollbar for sale in the Daytona area.It looks like it had the hard top on it for racing.http://daytona.craigslist.org/pts/2500535795.html
Junkyard_Dog
Junkyard_Dog Dork
9/25/11 1:01 p.m.
Shop around for the diff, Planet Miata is always pricey. Try Blake at isellmiataparts.com. I sold my torsen to a friend for $500 and his open diff, which I then sold as an update kit with axles and driveshaft for another $500. Of course I'm running a CTS-V/Getrag diff. now ($2000 give or take) so you'll need to save your axles and shaft if you stick with a stock style diff. housing.
For ultimate cheapness supposedly the Flea-bay OBX LSDs are fine if you replace the washers before installation. Info at: http://rbryant.freeshell.org/obx_washers.htm
codrus
codrus GRM+ Memberand New Reader
9/26/11 7:43 p.m.
Note that most (maybe all, not sure) of the Bethania Garage roll bar will physically fit with a hard top, but the ones that aren't specifically sold as HT-compatible will probably interfere with the use of the side latches. Many people simply take the side latches off and run without -- it's arguable somewhat less secure and a bit noisier, but it seems to work OK.
This is advantageous because the HT-compatible roll bars achieve this by locating the main hoop further back in the chassis, which means it needs to be an inch or so lower.
JALGcVjolPDbLqhBTYAlJ0HppmEbS8F9nzy2OFN7Fu3ERon4grG6VuPrfUTLcsTr
