My Daewoo of Death had a rust problem. First, the passenger side rear strut tower rusted through. Fixed that. The driver's side rear strut tower followed a year later. Fixed that. Then there was the sill on the driver's side that didn't look that bad and it wasn't functional and who cares it's a damned Daewoo.
However, this week I took a wire brush to this little bit of rust and discovered a collection of absolute horrors. The sill was packed with salt and rust - there must have been five pounds of loose crap I pulled out. Someone's idea of a "repair" in the past had evidently been to stuff the sill with cardboard and then slather a bunch of bondo OVER the rust. Once I got through the bondo I found four separate holes completely rusted through and the cancer was getting close to affecting the structural parts of the unibody.
So I panicked. I pulled out the cutting wheels and sliced off everything that looked even slightly suspicious. I was in that fugue state of mind where you are somehow both aware and unwilling to admit that you should probably not be cutting the bodywork off your daily driver with an angle grinder.
I spent the next couple of days driving around town with enormous grinder-holes in the sill, collecting necessary tools and materials, doing grad school stuff and reading Joey M's 32 Datsun build thread. I also used a pressure washer to clean out any remaining gunk I couldn't get with my fingers.
After several unsuccessful trips to used furniture stores, apartment complex trash heaps and the construction zone around a local middle school, I finally stumbled upon a recycling center that looked promising. I talked to the owners and after a little finagling they agreed to let me poke around their scrap piles. There, glimmering among the decaying refrigerators and toxic sludge puddles, was a glorious heated floor panel. It was perfectly flat, made of stainless steel roughly the same gauge as Daewoo body panels and mine for the princely sum of $1.78.
I took it home, cut it into strips and removed all the electrical/foam/thermal gubbins. With the materials ready I once more went into my apartment's underground parking garage, pulled out my collection of hammers, fired up the drill and prepared the rivet gun.
Basically I used the original body structure to provide a shape and then drilled holes into the good metal surrounding the voids I'd cut out. I then riveted the patch panel into place along the top edge, bent the patch around the remaining structure and then riveted it onto the bottom of the sill. After about three hours of grinding oil, sand and steel dust into my armpits, the whole thing looked suspiciously like a healthy sill.
Granted, the color isn't an exact match (gold patch, white car) and the panel doesn't perfectly blend with the original sheetmetal, but I think with a little bit of correctly applied bondo and a respray (which the car badly needs anyway), it will look pretty respectable. Pictures of this part coming soon.
My questions for the great GRM braintrust are thus:
Did I do anything fatally stupid?
Am I going to get a stainless/mild steel galvanic corrosion fuster-cluck of doom?
If I drill an access hole or two into the patch and fill the sill with expandable urethane foam to make it more weather-proof/structurally supported, will this have horrible unforseen consequences?
