QuikMcshifterson
QuikMcshifterson New Reader
1/25/23 12:12 p.m.
I'm lucky enough to live 1-mile from a McFadden-Dale store... they gots erra'thang!
NOHOME
NOHOME MegaDork
1/25/23 12:19 p.m.
And once you get bored with nuts and bolts, try and figure how to mix and match Metric and Imperial AC fittings in the same vehicle.
1/25/23 1:15 p.m.
Make all the places where they meet soft hose?
I have only done a couple AC swap kinda deals, and I went to a company that makes adaptors from all sorts of different kinds of compressor/condensor/etc to generic threaded O ring fittings, which made life SO easy.
bearmtnmartin (Forum Supporter)
bearmtnmartin (Forum Supporter) GRM+ Memberand UltraDork
1/25/23 5:10 p.m.
Since this is back from the dead, why can I not find JIS screwdrivers anywhere short of the internet, when every single Japanese bike in car use them?
NOHOME
NOHOME MegaDork
1/25/23 6:35 p.m.
In reply to Pete. (l33t FS) :
Have yet to find that vendor.
FJ40Jim
FJ40Jim Reader
1/26/23 12:45 a.m.
In reply to bearmtnmartin (Forum Supporter) :
I have a set of JIS Phillips drivers to work on Japanese carbs & distributors (my 'real' job). The JIS screwdrivers were an exciting new tool for a few days, but ultimately I havent found any real improvement over a good quality Mac or S-K driver with grit blasted tip.
SupraFiend
SupraFiend New Reader
4/8/23 4:24 p.m.
One thing I'll add to the conversation, never assume that because your tap and die set has a size in it, that you can find a bolt to match it.
I once bought a used aluminum flywheel for 50 bucks because its pressure plate bolt holes had all been stripped. No problem I thought. It had m12x1.5 holes originally, so I grabbed the m13x1.5 tap from my set and upsized it by one. Next step, order new bolts. Ha! They don't exist.
djsilver (Forum Supporter)
djsilver (Forum Supporter) Reader
4/8/23 11:47 p.m.
Knurled. said:
ebonyandivory said:
Screw you and your Metric and Imperial sizes.
Signed: Torx
Torx is available in standard and metric.
(Want to find a standard Torx?  Look at Ford seatbelts from the 70s.  Seatbelt fasteners are always 7/16-NF, and Ford used Torx)
Seatbelt anchor bolts are either 7/16 NF or M11-1.25 because they're functionally equivalent.  They're not identical but they're cross compatible.
itb76
itb76 New Reader
4/8/23 11:50 p.m.
In reply to spandak : I get most of my fasteners from McMaster-Carr. They don't ship in super small quantities but I like to keep extra of the common size in stock. Great variety of sizes and grades.
tB0rf8NEbS8XeaesrkzPxT7R2omvZpofDWO86VOEuXNaugxJKnXPK1Fqp8ftDIdO
