NBS2005
NBS2005 Dork
8/5/09 11:20 a.m.
My Mazda MPV (2001, 2.5 L) needs to have it's coolant topped off every 2K miles or so. Probably no more than a pint. Is that normal?
Reason on ask is that it still has that low idle miss. No problems at speed, mileage has not changed. It's got 105K on the clock and is using about 0.5 quarts of oil in the same time frame. Oil looks good, no froth.
Thanks
914Driver SuperDork
8/5/09 11:33 a.m.
Where's it going?
Strizzo
Strizzo SuperDork
8/5/09 11:49 a.m.
When's the last time rad cap was changed?
amg_rx7
amg_rx7 Reader
8/5/09 11:59 a.m.
Coolant System Pressure Tester - rent it from Autozone and test your system.
Jensenman
Jensenman SuperDork
8/5/09 4:54 p.m.
A pint of coolant in 2K would concern me. That's too much to attribute to evaporation etc but too slow to be a big leak. Dump some fluorescent dye in the coolant, run it a K or so and then check it over carefully. Something I learned from dirt biking: run the engine outside in the dark and shine the blacklight at the exhaust. If you see little yellow twinkles in the exhaust, you got something going on.
iceracer
iceracer HalfDork
8/5/09 7:08 p.m.
Low idle miss and coolant loss would concern me.
fastmiata
fastmiata New Reader
8/5/09 7:50 p.m.
My guess is that one of the small coolant lines attached to the water pump is seeping.
NBS2005
NBS2005 Dork
8/5/09 9:56 p.m.
Thanks for the info. I'll start with a pressure check. Then I'll do the dye trick. I hope it's nothing big, that van is a PITA to work on.
Schmidlap
Schmidlap Reader
8/6/09 8:16 a.m.
Is that the Mazda 2.5L (as in the MX6/Probe) or the Ford 2.5L (as in the Contour/Cougar)? My Ford 2.5L had a leaky water pump gasket (after about 180,000 miles) that caused the same problem. I replaced the entire water pump just to be on the safe side, but the gasket by itself is available from Rock Auto.
Bob
7pfoN6vUeG6VJZf9FbPYHHKkO9GDYUKiLxB1rM0dpjdSBpGrkKSpFTmXILPfp7w9
