Dusterbd13
Dusterbd13 Dork
2/21/14 8:59 p.m.
so i have a suspected vacuum leak on a 3.4 Camaro engine. cold idle (with good IAC) is 900 RPM. as the engine warms up/during drive cycle, idle increases to a max of 2000 rpm. will not come down. after shutdown, still warm, idles 1500-1700.
im thinking vacuum leak. also little rich, and throttle response is kinda soggy. not exceptionally horrible on either (like it was when I started in on it), but noticible to me.
ive never had any luck doing the spray carb cleaner trick, and holding a giant thing of propane around hot headers hiven me the willies. what other options do I have?
also, anything else that could be amiss that im not thinking of?
turboswede
turboswede GRM+ Memberand UltimaDork
2/21/14 9:08 p.m.
Smoke test. Maybe use a smoke generator like the bee keepers use.
maj75
maj75 New Reader
2/22/14 6:49 a.m.
Cigar! If you don't imbibe, get a friend. It works!
DrBoost
DrBoost PowerDork
2/22/14 7:18 a.m.
Yup, smoke machine.
oldopelguy
oldopelguy SuperDork
2/22/14 9:23 a.m.
Starting fluid works way better than carb cleaner, though you have to use the straw from the carb cleaner.
Dusterbd13
Dusterbd13 Dork
2/22/14 12:20 p.m.
yup. no vacuum leaks. and im now out of ether AND propane.
but after switching out the ECM for a known good one, all my problems resolved.
damn engine swaps.
and I saw the cigar trick on google, but dodnt think it sounded like it would actually work. whats your procedure?
wRZyWZ9uobKQsbQlAIUqMBMdtFP5GKcmcZfrXCVgniLRg30pIexX4hb5zjbJYsLm
