Toyman01
6/6/16 1:43 p.m.
Anyone know how much room under the hood of a 1988 740?
Width between the strut towers. Distance from the firewall to the radiator. Top of the cross member to the top of the struts.
Any info would be appreciated.
EvanB
EvanB GRM+ Memberand UltimaDork
6/6/16 1:51 p.m.
I don't currently have any to measure but if noone else has the info I could measure one of the ones my friend has in a couple days.
JohnRW1621
JohnRW1621 MegaDork
6/6/16 1:54 p.m.
I think it is known that the Ford 4.6L is too big for Volvo but Ford 5.0L is the answer.
clutchsmoke
clutchsmoke SuperDork
6/6/16 2:03 p.m.
EvanB wrote: I don't currently have any to measure but if noone else has the info I could measure one of the ones my friend has in a couple days.
The last time I saw my 740 he was behind the wheel giving it a new home. There's a lot of room in there.
Toyman01
6/6/16 2:08 p.m.
Is the 740 similar in size to a 240. I came up with these on another forum.
240 engine bay
850 firewall to radiator support panel, then about 250 forward of that to the grill
770 between top of the strut towers
700 between chassis rails
600 cross member to top of strut towers
That give me almost 6" in width. Very little in height and 6 in length. I know the transmission tunnel would need some work.
EvanB
6/6/16 2:42 p.m.
The 740 should be similar but with less height.
chiodos
chiodos Dork
6/6/16 2:44 p.m.
Some norwegian put in a dohc 4.6 in a 240 and iirc didnt have to cut the towers.
Gotta ask, whats your plan?
Edit: posted your question on a volvo site, ill let you know with answers in a hour when im off work if someone doesnt beat me too it
Toyman01
6/6/16 3:17 p.m.
In reply to chiodos:
The thought is all usable parts out of this:
Into this:
Engine, transmission, rear axle and so forth. Should be a fun sleeper for less than Challenge money.
Toyman01
6/6/16 4:25 p.m.
Well, lookie what I found.
DOHC 4.6 into a 240.
And the DOHC is wider than the SOHC.
Streetwiseguy PowerDork
6/6/16 4:58 p.m.
The opening is plenty big. You might run into issues with brake booster interference, and that sort of stuff.
chiodos
chiodos Dork
6/6/16 5:03 p.m.
Toyman01 wrote: Well, lookie what I found. DOHC 4.6 into a 240. And the DOHC is wider than the SOHC.
Thats the one i was talking about earlier! And thats where i asked your question but unfortunately haven't gotten a response, but it seems you have your answer
And in reply to what streetwise said about the brake booster, the dohc 740s have a slim brake booster so if you do have a problem there, theres a junkyard bolt in available solution.
Toyman01
6/6/16 5:07 p.m.
The one above used the hydro-boost off of the Mustang and did away with the vacuum booster.
chiodos
chiodos Dork
6/6/16 7:15 p.m.
In reply to Toyman01:
Yeah but its a 240 and iirc the boosters dont cross over. That said it looks like the dohc takes up too much space even for the slim one. Dunno about the sohc but im still waiting for dimensions on that site...they arent as awesome as this one
TjtdnSWUypPiPZuyHejpduapf2iw3GLKUXPKDed1KJHhON2txiwtLEsYXvFlGosD
