cabbagecop
cabbagecop New Reader
4/24/13 7:37 p.m.
Got a VW question. I need new drive flanges for my 85 Golf but it appears the 90mm ones are not available anymore. To switch to the 100mm ones do I need anything besides the flanges and new axles?
Travis_K
Travis_K UltraDork
4/24/13 8:37 p.m.
Flanges, seals, axles, and maybe hubs, not sure about the last one though. I know the outers arent the same, but I dont know if they go into the same hubs.
chandlerGTi
chandlerGTi Dork
4/24/13 8:40 p.m.
Outers are 100mm also although I believe you can order 90-100 intermingled axles or just build your own.
Did you try buying used flanges? I have a couple trans sitting here...
Travis_K
Travis_K UltraDork
4/24/13 9:00 p.m.
I know if you put the 90mm outers on the axles for the 100mm inners they slide back and forth on the splines.
cabbagecop
4/24/13 11:12 p.m.
I have been looking for some used ones but haven't had any luck yet. I planned on changing the whole axle if I do this. I am hoping I don't need to change the hubs because I just put new ones on when I changed the wheel bearings.
Knurled
Knurled GRM+ Memberand UltraDork
4/25/13 5:55 a.m.
Hubs are the same but the 100mm axles don't fit in some knuckles without grinding. I think this is just an A1-chassis issue, though.
xflowgolf
xflowgolf HalfDork
4/25/13 9:44 a.m.
get a set of flanges in a junkyard?
There's got to be countless old junk trans' from the '80's era piled in garages/barns across the country.
I probably have a few sets of 90mm flanges in my garage somewhere.
I guess my point being, try looking outside of new, they're not a normal wear item so any set should be fine.
chandlerGTi
chandlerGTi Dork
4/25/13 2:55 p.m.
I just dug out a set, send me a pm
mVzx7q9R0XpoaPkIKv2QoQm7eTxo8t5QdMRKQQIZJy8YbJm00HLxm9Ew1oMHuzE4
