My friend has a 1996 Mk3 Golf with a 2.0L 8V engine that his son drives to school. A couple of weeks ago the belt snapped at low RPM. I have seen conflicting information as to whether or not this engine is an interference motor. As best I can tell it is interference, but just barely, so if the belt snapped at low engine speed there is a very low chance of damage.
My friend is quite skilled mechanically and is trying to show his son the ropes, so he had his son tear down the car for belt replacement. The car has an aftermarket adjustable cam gear. In the course of stripping the side of the motor down his son got the adjustments on the cam gear all jacked up. They put the belt on but the car wouldn't run.
They have a 1990 or so Mk2 Jetta with an 8V motor (probably 1.8L). They pulled the stock cam gear off the Jetta and installed it on the Golf motor. The car still won't run. My friend tried adjusting the cam gear a couple teeth forward and a couple teeth back but the best result was a sputtering attempt to start.
I did some looking around on Rockauto.com and learned the cam gear for the 1996 Golf was used on a whole bunch of VW models, but NOT Mk2 Jettas other than the 1985 GLI model.
Does anyone know what the differences between these cam gears might be? I'm thinking maybe a different number of teeth, but it could be as simple as the timing marks being different.
My friend thinks the cam gears are probably the same since the gear fits on the cam and the belt fits on the gear. He thinks maybe the car has an aftermarket cam since it has some other performance parts (intake, header, suspension, wheels).
My friend has helped me out with car problems when I have gotten in over my head more times than I can count and I'd like to be helpful in this case.
Here is a picture of my old 1991 Escort GT in pickup mode for your troubles.
