novaderrik
novaderrik UltimaDork
3/14/15 1:57 a.m.
neat stuff, that's what's inside my rearend..
gears and stuff... it's a factory locker installed in a 2002 Z28 rear that i just picked up for my POS 86 Camaro..
all of that magical wonderfulness is inside this housing:
finally found the exact rear axle i've been seeking out for a while now- 3.42 gears, locker differential, disc brakes, 70,000 old man driven miles- and i paid about half what they usually go for.. also got the gas tank with the LS1 fuel pump for whenever i get the 5.3 together and the brake master cylinder so now my whole brake system will be 98-02 F body.. i wanted the aluminum driveshaft, but i didn't bring along enough cash to get that..
The_Jed
The_Jed UberDork
3/14/15 4:56 a.m.
Nice score! Looks pretty clean for 13 years and 70,000 miles. You have a nice rearend.
moparman76_69
moparman76_69 UltraDork
3/14/15 6:11 a.m.
wheelsmithy
wheelsmithy GRM+ Memberand HalfDork
3/14/15 8:24 a.m.
moparman76_69 wrote:
better be set on vibrate
Gary
Gary HalfDork
3/14/15 9:09 a.m.
Best thread title in a long time, maybe ever!
+2
novaderrik
3/14/15 9:41 a.m.
wheels777 wrote: IIRC, the '02 is 3-5/8" wider than the '86. I have a 9-bolt for sale that I originally picked up for my 87. It is cleaned up with about $200 worth of new brake parts on it. 3.27:1 gears, posi, bolt in axles...nice piece. Asking $275
yeah, my rearend is wider, but that's ok..
failboat
failboat UltraDork
3/14/15 11:04 a.m.
I was reluctant to click on the thread but figured since it was posted in the "GRM" forum instead of off topic it was probably okay.
Giant Purple Snorklewacker
3/14/15 11:11 a.m.
Wow! It's clean. Looks nice and tight. All lubed up and ready to go!
ronholm
ronholm Dork
3/14/15 11:15 a.m.
Really looks like it can take a pounding. and burn some rubber..
patgizz
patgizz GRM+ Memberand PowerDork
3/14/15 11:31 a.m.
get zr1 replicas in 88+ vette offset for rear and 84-87 offset for front, or just use spacers up front?
Mr_Clutch42
Mr_Clutch42 Dork
3/14/15 11:48 a.m.
I thought that the 4th gen is 4" wider total than the 3rd gen rear end. Get some performance rear brake pads too if you're driving it hard/auto-x'ing the car.
moparman76_69
3/14/15 12:09 p.m.
In reply to wheelsmithy:
That's a toy car.
3/14/15 2:01 p.m.
In reply to moparman76_69:
novaderrik
3/14/15 6:01 p.m.
my GTA's will fit nicely and should be herra frush once i get it all bolted together..
wheelsmithy
3/14/15 6:36 p.m.
moparman76_69 wrote: In reply to wheelsmithy: That's a toy car.
Well, that's got no purpose at all...is that the dead guy from Jackass?
novaderrik
3/15/15 12:52 p.m.
i got so excited about my new rearend, that i decided to do a little simple fab work on the control arms that came with it.. now i have two stiff arms to hold my rearend.. even ran some sheetrock screws into the bushings and ground off the heads to stiffen them up a bit, and may get a tube of window weld to fill in the 30% or so of the bushing space that they didn't fill with rubber at the factory to maintain a nice cushy ride- in a Z28 convertible, where "cushy ride" shouldn't even have been a design consideration.. it's cheaper and easier than new bushings..
hyJZNXPsQ0HvLNkONfEtJRJ1LhkLKVIT4vIjZXews3BuvZZTKvOCgfumRwoDRCtj
