RevRico
RevRico GRM+ Memberand UberDork
8/18/18 1:05 p.m.
I'm trying to remove the shock in the picture. There are supposed to be flats where a wrench goes to hold that shiny shaft still while I turn the but on top. There aren't, I can't make the shiny part stop spinning.
What am I missing? How stupid/dangerous would cutting or welding a way to stop it from spinning be?
Edit: before "but rev, there's a collar there" the collar spins freely of the shaft.
barefootskater
barefootskater HalfDork
8/18/18 1:13 p.m.
Vice grips?
RevRico
8/18/18 1:18 p.m.
In reply to barefootskater :
Just spins, even with a piece of rubber in the teeth. .
I need to buy a nut splitter
Dusterbd13
Dusterbd13 MegaDork
8/18/18 1:23 p.m.
Sawzall the top nut off
gumby
gumby GRM+ Memberand Reader
8/18/18 1:33 p.m.
Many times the top of the shaft is hex. Use one wrench to hold the hex and another to turn the nut.
Or use an impact.
Or a deepwell socket with a long extension is usually enough leverage to break the top of the shaft off below the nut.
RevRico
8/18/18 1:38 p.m.
Dermal was taking too long, I was about to grab the death wheel but this sounds slightly simpler
Floating Doc
Floating Doc GRM+ Memberand HalfDork
8/18/18 1:58 p.m.
I was doing a shock swap on one of my panthers, and encountered this on the last one, driver's side front.
All I had was hand tools, so an impact wasn't an option. Didn't have anything to cut it with either. I took it to a shop where they quoted me a big chunk of money.
Just then, the mechanic walked back out of the shop with about a 4-foot extension and a deep well socket and popped the end of it off. Took him no more than two seconds.
noddaz
noddaz GRM+ Memberand SuperDork
8/18/18 2:12 p.m.
This is the answer if you have enough room to swing the extension back and forth.
DqcIInGHWjzhaKy00oeb1DTxhzDkBTwSVoHhdb07JnLUn26xOAxeu7MeIVvoro4X
