Dusterbd13
Dusterbd13 PowerDork
10/16/16 9:12 p.m.
https://goo.gl/images/WXSURj
And where do I find them, or how do I make them? Already have the heims and swedged tube, but not the "tabs"
I'm sure it's simple, but my brain just won't come up with it.
Edit: I fail at hotlinking.
wae
wae Dork
10/16/16 9:16 p.m.
I made mounting tabs for a similar strut rod by drilling holes in steel bar stock then bending it into a C.
EastCoastMojo
10/16/16 9:17 p.m.
Dusterbd13
10/16/16 9:19 p.m.
I'd like to use flat stock. Except the part where I have no idea how to turn it into a proper shape with a bench vise.
And thanks eastcoastmojo!
Apis Mellifera
Apis Mellifera HalfDork
10/16/16 9:54 p.m.
Shock or radius brackets. The Chassis Shop has them.
Like-a theese?
wae
wae Dork
10/16/16 10:03 p.m.
Dusterbd13 wrote: I'd like to use flat stock. Except the part where I have no idea how to turn it into a proper shape with a bench vise. And thanks eastcoastmojo!
I went pretty caveman on it since my bench vise sheared off its mount after a ball joint press incident. I cut the bar stock to the total length I needed, then put my three holes in it -- one for mounting on the control arm bolt and two for the bolt that secures the heim joint. I put it in the vise which I kind of had to hold in place on the ground with my feet and then just beat it with a hammer until I had a 90 degree bend in it. For the second bend, I clamped the steel bar to a piece of wood that was the right thickness and hammered down the other end to complete the bracket.
Those tabs from the Chassis Shop look awesome though. Mine wound up looking like this (over there on the left):
codrus
codrus GRM+ Memberand SuperDork
10/17/16 12:00 a.m.
Yeah, it's basically just a piece of flat stock, cut to shape with your favorite cutting method, bent to shape (hammer it over a piece of square tubing, probably?), drill the holes, and then welded in place.
Or you can buy them here for $6 each.
http://www.kineticvehicles.com/brackets.html#suspension
Run_Away
Run_Away GRM+ Memberand HalfDork
10/17/16 12:09 a.m.
I'd use a square or rectangle tube cut in half if you want thicker stuff.
STM317
STM317 HalfDork
10/17/16 4:35 a.m.
Usually called shock tabs or shock mounts. If you decide not to fab your own, they're pretty cheap from places like Summit or Speedway Motors. You should also check the airbag supply places like Airbagit.com
Dusterbd13
10/17/16 6:38 a.m.
In reply to Run_Away:
Ha!!! That's what my brain was trying to spit out but wouldn't. I've done it once before years ago, but couldn't remember.
stafford1500
stafford1500 GRM+ Memberand Reader
10/17/16 7:03 a.m.
there are these...
Chassis Tabs
I have a few in my stockpile. What hole size do you need and how quick do you want them?
Dusterbd13
10/17/16 7:20 a.m.
I need 5/8.
Pretty quickly actually. Fo7nd out that the amc is impossible to move without strut rods, and I cut the factory parts off already. So it's stuck on the lift, and I need the lift to fix other broken crap.
What thickness should I be looking for? I was thinking 12 gauge or so.
Wall-e
Wall-e GRM+ Memberand MegaDork
10/17/16 7:51 a.m.
I would imagine there is a circle track supplier not far from you that has them sitting on their shelf.
tuna55
tuna55 MegaDork
10/17/16 8:03 a.m.
Amazon also has them, but you have to figure out what they are (dimensions) from the catalog first.
https://www.amazon.com/s/ref=nb_sb_noss?url=srs%3D8202550011%26search-alias%3Dspecialty-aps&field-keywords=chassis+tab&rh=i%3Aspecialty-aps%2Ck%3Achassis+tab&ajr=0
stafford1500
10/17/16 9:33 a.m.
I think the ones I have are 3/8" and 1/2", but a drill can fix that. 12ga should be thick enough, but it may be better to go a little thicker, toward 3/16" or 1/4" since they are locating the wheels and you don't want the bolt wearing the holes out of round.
MulletTruck
MulletTruck Reader
10/17/16 9:39 a.m.
These guys have pretty much everything you need for that kind of stuff.
http://www.ruffstuffspecialties.com/catalog/shockbracketstabs.html
Dusterbd13
10/17/16 9:48 a.m.
In reply to stafford1500:
do you have 4 of them? and a free night to get togheter this week?
stafford1500
10/17/16 10:30 a.m.
I will check my stash this afternoon and call you.
NOHOME
NOHOME PowerDork
10/17/16 11:25 a.m.
http://welderseries.com/blog/
Buy the stuff ready made or steal the design and make your own.
Crackers
Crackers Reader
10/17/16 11:31 a.m.
I'd go 1/8" plate. If you can find the right dimension, just buy some square/rectangle tubing and cut out the side with the seam.
MulletTruck
MulletTruck Reader
10/17/16 1:10 p.m.
I use 2X4X125 rectangle tubing to make mine. id is perfect when using the high action spacers.
Crackers
Crackers Reader
10/17/16 1:38 p.m.
MulletTruck wrote: I use 2X4X125 rectangle tubing to make mine. id is perfect when using the high action spacers.
This is basically what I reccomend. Only thing I would do different is stand it on edge to make a pocket, instead of two tabs.
On edit: Maybe you have an old control arm you can section to make mounts?
Huckleberry
Huckleberry MegaDork
10/17/16 1:41 p.m.
Summit, Speedway, etc all carry them in the circle track stuff.
Mad_Ratel
Mad_Ratel Dork
10/17/16 2:16 p.m.
take a look at the locost guys. They make these things all the time.
MulletTruck
MulletTruck Reader
10/17/16 3:50 p.m.
This time I needed it to be a little longer than the 2 inch would allow. A lot of the time I would cut out one side and leave the back of it intact, I will probably end up doing that on this application next time I go to the store that sells steel plated gold AKA Industrial Metal Supply
Qnj0khRTnBY8IGVNfySTG96vBwO7pAzBAKQucUAUu7YOgw7IitxvQOkjbpo9fc90
