Ovid_and_Flem said:
In reply to ClemSparks :
I want to reiterate Clem's thoughts on the bang for the buck of a C4 as eviidencsed by Pete's project. I stumbled into my old c4 challenge project on the cheap ($500 for a trashed, non running lots of body damage, specious hacked up peckerwood wiring repairs over 30 years) BUT my direction was far different from Pete's efforts to build a presentable streEtable car.
There are $500-$1500 c4 out there but they will require a lot of work and nickle and dime stuff will cause the price of Poker to go way up. In Petes case he will end up with a nice reliable classic slightly under challenge budget. But keep in mind...Challenge budget rules exclude rebuilding things like brake systems which can run $500 to $1000. And performance rubber ain't cheap.
I almost think if you want a decent c4 you're better off starting with a decent, clean drive able model in the $3-5K range.
That being said, you start with a cheap old car that comes with forged aluminum suspension components, aluminum driveshaft, IRS, LSD, r&p steering, 4 wheel disc brakes , composite (leaf) springs, close to 3,000 lbs, etc. Don't forget these old cars stunned the automotive press when it was able to pull close to 1 g on the skippad. Still a performance bargain in the big scheme of things. Even if you have to start out at the $3-5K range for a decent one.
I have to say though...I've had a saved search on my local craigslist for 2 years now for "Corvette" and "$4,000 max price." Right now there are zero results that are actually for a Corvette.
NOTHING has come along in those two years I've even felt tempted to make a lowball offer on. I can't imagine a place where something is worth LESS than it would be worth in the middle of Missouri. So, basically all this talk of C4 is wasted breath.
That made me go look at Mustangs with 8 cylinders under $4K. There is one. Listed at $3K it is barely within striking distance of the OP's target Budget.
Camaros under $4K: One. Listed at $4K...Double the intended price range.
That said, we're a pretty small area so I guess a larger area might have more results. Also...the deal will come along eventually...You'll just need to know it's a deal when it comes along and be ready to act.
