Taiden
Taiden UltraDork
8/27/13 7:06 a.m.
I am not above admitting that I use wd40 on everything, but that has to change now that I am doing more metal fab.
What steel cutting fluid is decent and readily available (or cheap to get on Amazon Prime)?
93EXCivic
93EXCivic MegaDork
8/27/13 7:13 a.m.
Tap Magic? That is what I have always used. Although at work I am trying out Anchorlube G-771.
EvanB
EvanB GRM+ Memberand PowerDork
8/27/13 7:23 a.m.
93EXCivic wrote: Although at work I am trying out Anchorlube G-771.
That is some good stuff.
logdog
logdog GRM+ Memberand Dork
8/27/13 7:45 a.m.
93EXCivic wrote: Tap Magic? That is what I have always used. Although at work I am trying out Anchorlube G-771.
How many moving parts does an anchor have that it needs special lube?
ditchdigger
ditchdigger SuperDork
8/27/13 8:05 a.m.
The most common one I can think of.
Dr. Hess
Dr. Hess UltimaDork
8/27/13 9:43 a.m.
I use tap magic.
Driven5
Driven5 Reader
8/27/13 10:02 a.m.
Another Tap Magic user here.
Kenny_McCormic
Kenny_McCormic SuperDork
8/27/13 10:13 a.m.
Tap magic, the name doesn't lie. Or 80w90 GL5 gear oil in a pinch.
DaveEstey
DaveEstey UltraDork
8/27/13 10:14 a.m.
I use MMO
2002maniac
2002maniac HalfDork
8/27/13 12:37 p.m.
tap magic for aluminum. moly d for steel
Kenny_McCormic
8/27/13 3:25 p.m.
In reply to 2002maniac:
No, its Tap Magic aluminum formula for aluminum.
Taiden
Taiden UltraDork
8/27/13 10:06 p.m.
Where the heck to I buy this stuff? Is it an autozone/NAPA type of thing? The local big box places dont seem to carry any of that stuff.
yamaha
yamaha PowerDork
8/27/13 10:27 p.m.
Tap magic, Id just go to a local industrial supply store for access to the full line of their products. Or check this..... http://www.tapmagic.com/TMwhere.htm
You're out of our sales region or I'd say us. We get in trouble with territories though.
benzbaronDaryn
benzbaronDaryn Dork
8/27/13 11:26 p.m.
There is tap fluid in home despot plumbing section, I just got a quart of the stinky stuff.
jere
jere HalfDork
8/27/13 11:46 p.m.
benzbaronDaryn wrote: There is tap fluid in home despot plumbing section, I just got a quart of the stinky stuff.
Is that this stuff?
chaparral
chaparral GRM+ Memberand HalfDork
8/28/13 12:06 a.m.
Ordinary used motor oil is good for cutting or drilling steel, but don't expect to paint or weld the part until it is thoroughly cleaned. You'll need at least hot soapy water or TSP. The same properties that help it adhere to surfaces to provide boundary layer lubrication when needed will continue to provide boundary layer lubrication when you'd rather replace the boundary layer with something else.
benzbaronDaryn
benzbaronDaryn Dork
8/28/13 12:58 a.m.
Thats it Jere, stuff makes a mess and literally I feel coated after using it. I agree a pain to clean after using.
93EXCivic
93EXCivic MegaDork
8/28/13 7:29 a.m.
Both the Anchorlube G-771 and Tap Magic are available on McMaster Carr. Tap Magic is about twice the price though.
Duke PowerDork
8/28/13 8:05 a.m.
My father used to use something called Mr. Cool Tool in the machine shop.
iceracer
iceracer UberDork
8/28/13 9:46 a.m.
For years we used a mixture of water and a soluble oil. Don't remember the brand of oil.
motomoron
motomoron Dork
8/28/13 10:00 a.m.
For threading AL I keep Relton Rapid-Tap and Tap-Magic aluminum formulation on hand.
Milling and turning AL I use WD-40. Actually, it's all I use it for. It's only barely a lubricant 'til it evaporates, then it's nothing.
Turning and milling mild steel can be done dry on 12L14, a leaded, free-machining alloy. I use the smelly brown sulphur-based oil on 1020 and such if it's needed, and for threading in all steels.
I have flood coolant systems on the lathe, mill and horizontal band saw as well as droplet on the mill. I keep Rustlick WS50 in those mixed about 20-1. I use it in the saw almost always, turning larger stainless and any really big steel parts, and occasionally milling stainless.
If you're doing mostly steel just hit Home Despot for a bottle of Rigid pipe threading lube. Use ATF for tapping AL.
stafford1500
stafford1500 GRM+ Memberand Reader
8/28/13 10:04 a.m.
For titanium machining and turning, the homegrown lube is milk. Basically water with fat suspended in it (I would go with whole milk, not that skim stuff).
jimbbski
jimbbski HalfDork
8/28/13 1:55 p.m.
When I machine AL I have used mineral sprits and/or kerosene for lube. When tapping AL I use a lube for AL threading. On most steels I just use a common cutting lube but when tapping I use the good stuff Tap-Magic, Rapid-Tap, or similar. I have no favorite.
frenchy
frenchy Reader
8/28/13 9:54 p.m.
Tap magic, anchor lube, TD foamy all work well. Mike'O'Cut is another. All are available at your local Fastenal.
jere
jere HalfDork
8/29/13 1:08 a.m.
Any recommendations for a horizontal bandsaw and mild to hardened steel anyone? I need to find something too, and am getting lost different choices.
jg9IsLdSSfwl7yjtSw22Zqaf6d8pvYyAbKBS2zbSokjd2d32w8DxD68ofChwVlOw
