6/14/12 8:43 p.m.
I know, how big is a rock.
I was just going through some papers and found my notes from when I had my '92 Miata head done in 1999 or so. Looks like it cost $1615 for all of the work: port work, new valves, cutting the deck, etc. I think we checked off a bunch of boxes on that one. That's also about $200 less than I paid for the Porsche heads. Just wondering what you guys are paying.
6/14/12 8:43 p.m.
Oh, a PS: I still have the car and drove it today. It still pulls very nicely.
spitfirebill
spitfirebill UltraDork
6/14/12 8:48 p.m.
I paid $200 to Dover Head in Greenville, SC to "do" my head. I disassembled it and did port matching. I took it over as a bare head and provided new valves, guides and springs. The head already had hardened seats. They cleaned it, did a three angle grind, cut the head 0.050" and put it together.
curtis73
curtis73 GRM+ Memberand SuperDork
6/15/12 1:05 a.m.
A simple deck resurfacing for me at the shop was $65 for one, $85 for two. If I added a valve job it was another $85.
Port work? Way too hard to tell. Common stuff like Chevy heads I used to pay $105 per head for a gasket match and $135 if it included a bowl blend. I had a customer pay $2100 for fully porting/flow testing his Maserati Biturbo head.
Like you said, How big is a rock?
cpdave
cpdave New Reader
6/15/12 5:21 a.m.
I have $1724 plus $200 core in the #...302 heads on my Dart:
They have 1.94"/1.6" valves and support 330 RwHp and 303 RwFtLb at 0.600" lift and 10.1:1 compression on a 0.040" over 318.
Dave
wheelsmithy
wheelsmithy GRM+ Memberand Reader
6/15/12 6:19 a.m.
Suzuki G13b seven new valves, decked, 3 angle valve job, new seals (I supplied those) right at $500
T.J.
T.J. PowerDork
6/15/12 6:24 a.m.
I spent something like $300 IIRC on my BMW M10 head last year. I disassembled it and they cleaned it, decked it, checked it for cracks, and did a valve job. I put it all back together. No porting or anything fun.
Curmudgeon
Curmudgeon MegaDork
6/15/12 6:42 a.m.
Ummm... I bought a used center iron for a 13B for $40...
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
6/15/12 6:48 a.m.
I usually buy heads that were already built from abandoned projects. Much cheaper that way. Paid $100 for my built F2T head. All new parts, big port job, dual valve springs, and a Delta 272 cam.
Zomby Woof
Zomby Woof UltraDork
6/15/12 7:59 a.m.
Cylinder heads is what I do.
For a Swift GT DOHC G13 I charge $750. That includes street/race porting, rebuild with bronze manganeze guides, 3 angles on the head, cam grind of your choice, lifter disassembly and cleaning, reface for squareness or compression, and assembly. Add 1 pc SS valves $150, add swirl polished valve with undercut stems $225.
For a G10 3 cylinder, it's $425 plus $60 or $90 for valves, in either performance or economy cam grind and porting.
92CelicaHalfTrac
6/15/12 8:05 a.m.
Zomby Woof wrote: Cylinder heads is what I do. For a Swift GT DOHC G13 I charge $750. That includes street/race porting, rebuild with bronze manganeze guides, 3 angles on the head, cam grind of your choice, lifter disassembly and cleaning, reface for squareness or compression, and assembly. Add 1 pc SS valves $150, add swirl polished valve with tapered stems $225. For a G10 3 cylinder, it's $425 plus $60 or $90 for valves, in either performance or economy cam grind and porting.
Hot damn! You do other heads?
Brett_Murphy
Brett_Murphy GRM+ Memberand Dork
6/15/12 8:22 a.m.
I'll let you know shortly, I've got to get a head done soon. Of course, with my project, "soon" means sometime before next year.
Ranger50
Ranger50 SuperDork
6/15/12 8:26 a.m.
I dunno.. last set of Ford E7's, stock 5.0 Mustang heads, I had redone cost over $1600 for the pair. No porting, no nothing "special". Just a rules restricted pair of heads, I think.
Giant Purple Snorklewacker
Giant Purple Snorklewacker UltimaDork
6/15/12 8:32 a.m.
$425 for a BMW S52 (the whole engine family)
That is cleaning, decking, checking, grinding the seats, replacing the guides/seals (I provide parts) and usually a good story about racing at the Pocono Drag Lodge back when dinosaurs roamed the earth and women knew their place.
Ian F
Ian F UberDork
6/15/12 9:31 a.m.
I think cost depends too much on the engine and how easy it is to find someone who knows how to work on them. I would expect to pay far more to have a single Volvo B20 head ported than a pair of SBC/F/M (maybe a bit more for Mopar) heads simply due to the fact there's only one guy I trust to have it done and he's on the other side of the country. I feel reasonably confident my local speed shop could do a set of American heads or even most Asian car heads.
Alan Cesar
Alan Cesar Associate Editor
6/15/12 9:40 a.m.
My valve job last year cost me:
1 spark plug socket that we cut a window in with a Dremel to serve as a valve spring compressor (in concert with a big C-clamp)
16 valve stem seals
1 cheap and crappy valve lapping tool
1 tub of lapping compound
1 tube of RTV sealant
1 tube of grease
1 spray can parts cleaner
1 spray can of ether (to check for leaks)
1 valve cover gasket (part of complete engine gasket kit)
1 cylinder head gasket (part of complete engine gasket kit)
Several hours of bonding and work with my dad
Some of those things we had laying around, of course. I didn't use a whole tube of RTV or grease.
oldtin
oldtin SuperDork
6/15/12 9:59 a.m.
$300 for the TR4 - decked, guides/seals...
oldeskewltoy
oldeskewltoy HalfDork
6/15/12 10:49 a.m.
I'm doing a fair share of heads these days... a typical 4AG head will usually run about $600-$800.
The breakdown... $350 for cleaning, decking, and a 3 angle $250-$450 for porting... depending on how extensive a job
SOME heads(my most recent one)... run over $2400... but that does include cams, O/S seat work, and HOURS of porting.....
Above is exhaust port #3 in transition. The far left panel shows the head as I got it from "another head porter".
here is a view @ a single bowl from #3 exhaust port
The call on this head was for O/S valves, with cam durations of about 300 degrees.
The lift is so much that the bucket cradles needed a little bit of massaging
Teh E36 M3
Teh E36 M3 Dork
6/15/12 2:37 p.m.
Alan-
I noted that you used valve grinding/lapping compound. I read somewhere (right after doing my 4age 20v) that this is actually bad, because the grit causes a valley between the valve and the seat. That a freshly cut valve seat and valve are far better. It sounded good, but I don't know.
I guess I shouldn't have puked when I got the estimate for $750 to cut seats, face, clean up and adjust valve clearances on the 20v.
Tom_Spangler
Tom_Spangler GRM+ Memberand HalfDork
6/15/12 2:43 p.m.
Teh E36 M3 wrote: Alan- I noted that you used valve grinding/lapping compound. I read somewhere (right after doing my 4age 20v) that this is actually bad, because the grit causes a valley between the valve and the seat. That a freshly cut valve seat and valve are far better. It *sounded* good, but I don't know. I guess I shouldn't have puked when I got the estimate for $750 to cut seats, face, clean up and adjust valve clearances on the 20v.
I lapped the valves on the GT-40P heads I had on my old Mustang. I did it by hand, just put a bit of lapping compound on the lip of the valve, then hand-spun the valve in the seat for a minute or two, then cleaned it up. I dunno, it certainly looked nice and smooth and even after it was done, and that engine always ran great and didn't burn any oil or anything. Surely not as good as a real valve job, but all it cost me was a couple of bucks for a tube of lapping compound and some time, so I figured what the heck?
Zomby Woof
6/15/12 4:28 p.m.
Teh E36 M3 wrote: I noted that you used valve grinding/lapping compound. I read somewhere (right after doing my 4age 20v) that this is actually bad, because the grit causes a valley between the valve and the seat. That a freshly cut valve seat and valve are far better. It *sounded* good, but I don't know.
There are two schools of thought there. Some claim that the compound actually damages the valve and seat over the short term, and causes the (valve/seat) seal to go bad prematurely. I've heard as little as 10,000 miles. Personally, I like to have verification of the seal and location, and have never had a return for damaged or leaking valves or seats.
Karl La Follette
Karl La Follette SuperDork
6/15/12 4:44 p.m.
Tom is on a special diet so we usually do salads with ham or turkey or roast beef . And we he is on bottled water .
friedgreencorrado
friedgreencorrado PowerDork
6/15/12 5:28 p.m.
In reply to oldeskewltoy:
Hey, that one looks like $2400 worth of work. Seems like the previous guy just made it shiny.
fornetti14
fornetti14 GRM+ Memberand HalfDork
6/16/12 10:15 a.m.
Subaru EJ25 heads $175 for the pair.
Includes pressure test, resurface, valve job and new valve guide seals. They come back looking like new. My favorite local machine shop sees Subie heads on a weekly basis thanks to their head gasket issues.
Your basic daily driver rebuild.
tr8todd
tr8todd Reader
6/16/12 10:40 a.m.
My last set(2) of Rover V8 heads including port work, new valves, new springs, and machine work to the valve pockets and guides was less than that.
InwFdXZlRnbirmohysRbeO9SsLXqnoGfc8MxLFDHT4Drg1c53p2qE7BExKqn31rb
