Flight Service
Flight Service MegaDork
8/29/14 9:51 a.m.
Don't say "yours" because you have it and can't find something,
But available engines and the reason.
I will start with the Toyota 1GR-FE 4.0L in the Tacoma. Supercharger and exhaust and that is about it. 4.0L with 236 hp and less that great fuel economy is really asking for some help.
Autolex
Autolex Dork
8/29/14 10:43 a.m.
VQ40DE (Frontier/Pathfinder/xTerra motor), came with 6 speed and 2 or 4wd options, should drop in just about anything that a VQ30/VG30/VG33/VQ35 should (deck height is a little taller) and they're DIRT cheap.
nderwater
nderwater PowerDork
8/29/14 10:45 a.m.
(Same wavelength) Nissan/Infiniti VQ35/VQ37. They've made a metric ton of these all-aluminum V6s in all manner of FWD/AWD/RWD applications and power levels.
Swank Force One
Swank Force One MegaDork
8/29/14 10:45 a.m.
Flight Service wrote: Don't say "yours" because you have it and can't find something, But available engines and the reason. I will start with the Toyota 1GR-FE 4.0L in the Tacoma. Supercharger and exhaust and that is about it. 4.0L with 236 hp and less that great fuel economy is really asking for some help.
There's turbo kits.
And they make obscene power. That motor is ridiculous.
wvumtnbkr
wvumtnbkr GRM+ Memberand Dork
8/29/14 10:48 a.m.
1.6 and 1.8L out of the mazda miata???
DaveEstey
DaveEstey UberDork
8/29/14 11:42 a.m.
Prius
SpeedAddict502
SpeedAddict502 New Reader
8/29/14 12:13 p.m.
Im going to say the IS-F. No one will hardly touch that engine and it is oh so glorious. But no tuning!
z31maniac
z31maniac UltimaDork
8/29/14 12:23 p.m.
nderwater wrote: (Same wavelength) Nissan/Infiniti VQ35/VQ37. They've made a metric ton of these all-aluminum V6s in all manner of FWD/AWD/RWD applications and power levels.
Huh?
You don't consider stroker kits, cams, headers, turbo and supercharger kits as "not much aftermarket" do you?
bmw88rider
bmw88rider GRM+ Memberand HalfDork
8/29/14 12:24 p.m.
Aren't late model toyota/lexus engines in general under represented? I really can't think of anything after the 3.0L straight 6 in the Lexus and the 2ZZ that has any real tuning support.
bigev007
bigev007 New Reader
8/29/14 12:31 p.m.
My Honda 1.3L, because... oh wait. d'oh. When I had a 3.4L GM car, I was surprised that an engine around that long (1982-2009ish) seemed to have no performance aftermarket support. There are a ton of them, they're reliable, and they sound good.
tuna55
tuna55 UltimaDork
8/29/14 12:33 p.m.
Nissan LEAF.
Seriously. It's artificially torque limited, but quick when it lets you have all of the torque. It seems relatively simply to alter that curve a bit. At least until stuff breaks.
dculberson
dculberson UberDork
8/29/14 12:35 p.m.
bmw88rider wrote: Aren't late model toyota/lexus engines in general under represented? I really can't think of anything after the 3.0L straight 6 in the Lexus and the 2ZZ that has any real tuning support.
By 3.0 straight 6 do you mean the 2JZ, one of the most tuned engines on the planet behind the small block Chevy? And the 2zz has an entire company based around tuning it, Monkey Wrench Racing.
I will say I think the 1UZ series needs more aftermarket attention. Yes, it's out there, but what's there requires a pretty high technical knowledge to make sense of what you need and how to install it. That's an engine you can get for peanuts in any major city that makes good power and is very compact and light. Perfect aftermarket swap opportunity. But still doing a manual swap or souping up the power requires a ton of know-how versus, say, a Chevy. Or 2JZ.
fidelity101
fidelity101 SuperDork
8/29/14 12:38 p.m.
Multi air? Maybe sky-active too.
bmw88rider
8/29/14 12:44 p.m.
Dculberson, I meant after those engines were retired. I know both of those have huge aftermarkets but name one engine after those that has any aftermarket at all. I don't count the motor in the Toyobaru as a toyota.
Hungary Bill
Hungary Bill GRM+ Memberand Dork
8/29/14 12:44 p.m.
I think almost every engine has "some" aftermarket. It's just the price that keeps "us" away. (ie: Toyota 1UZ and Audi ABH)
In theory every engine at least has an aftermarket ECU (megasquirt) and subsequently a turbo option (you just have to pay to have a turbo manifold welded up from the flanges you had your local machinist make from the gaskets you brought him/her, buy the turbo, run all the plumbing, intercooler, larger injectors, etc etc etc...)
yamaha
yamaha UltimaDork
8/29/14 12:53 p.m.
The 3.4L v8 from the 96-99 sho...... lightweight mill(lighter than an lsx) that has next to nil aftermarket support. Kinda sucks too, because those things should rev with an aftermarket set of cams and a ITB intake manifold and make close to 300whp while making a glorious exhaust note.
dculberson
dculberson UberDork
8/29/14 12:53 p.m.
bmw88rider wrote: Dculberson, I meant after those engines were retired. I know both of those have huge aftermarkets but name one engine after those that has any aftermarket at all. I don't count the motor in the Toyobaru as a toyota.
Ahh, yes! sorry, I mis-read the post. Now I understand.
tuna55
tuna55 UltimaDork
8/29/14 1:11 p.m.
Hungary Bill wrote: I think almost every engine has "some" aftermarket. It's just the price that keeps "us" away. (ie: Toyota 1UZ and Audi ABH) In theory every engine at least has an aftermarket ECU (megasquirt) and subsequently a turbo option (you just have to pay to have a turbo manifold welded up from the flanges you had your local machinist make from the gaskets you brought him/her, buy the turbo, run all the plumbing, intercooler, larger injectors, etc etc etc...)
I don't think Megasquirt can control the LEAF, and a turbocharger won't help at all!
Swank Force One
8/29/14 1:29 p.m.
The 2AZ/2AR motors have aftermarket. And make gobs of power.
Hungary Bill
8/29/14 1:35 p.m.
Touche!
oldeskewltoy
oldeskewltoy SuperDork
8/29/14 1:51 p.m.
depends on your budget....
this little baby(destroked 1GR) makes over 400 hp n/a
including the piece of wood!!!!
Swank Force One
8/29/14 2:08 p.m.
depends on your budget.... this little baby(destroked 1GR) makes over 400 hp n/a including the piece of wood!!!!
WHHHHAAAAAAAATT?!?!??!?!
tuna55
tuna55 UltimaDork
8/29/14 2:13 p.m.
In reply to Swank Force One:
Well the wood is just a isolating spacer. I am more interested in why the blurred out the little rectangle on the front.
Swank Force One
8/29/14 2:20 p.m.
That wasn't towards the "wood" comment. That was just... i can't brain around the idea that someone did that, and how much power it made.
kevlarcorolla
kevlarcorolla HalfDork
8/29/14 2:44 p.m.
Yeah whats going on in the blurred section?.
Cool,I see drysump so I'm thinking hardcore hillclimber/rockcrawler powerplant or something?.
odw6Nx5H7G3jYjiL4BYzZz5kOcPdc1qbjOUHpdF7sTxzx3ul3o35QRWrC5CJl3RT
