1 2 3 4
mtn
mtn MegaDork
10/20/14 3:15 p.m.
These are getting cheap. And they're perfect for me, even if they aren't a convertible. Except for the fact that the mpg sucks and the engine will blow up eventually.
But they are still cheap enough for me to look at. So here is my thought process: Buy one cheap. Drive it until the engine blows up. If it never does, great! If it does, then if you bought it right, it doesn’t matter. Say that I bought it, and the engine did blow up. What would you put in there in place of it? Lets look for something that will replace the same performance, be a more or less drop in swap (no V10 Viper engines), and be readily available. I’d be open to any suggestion, seeing as this is just an exercise in boredom at work and it has approximately 0.01237% chance of ever happening--I'm pretty well set on an E46 convertible.
wvumtnbkr
wvumtnbkr GRM+ Memberand UberDork
10/20/14 3:18 p.m.
I think the easy button is another Renesis.
The big issue is the CAN system the car uses. Pretty difficult to get all of the sub systems to work properly in the car with a swapped engine. I have heard that there was (1) company that cracked the CAN system. Not sure if they still exist.
If that doesn't matter... LSX.
Rob R.
bobzilla
bobzilla MegaDork
10/20/14 3:21 p.m.
4.8 truck engine, cam/valvesprings, FAST intake w/90mm TB tuned to run appropriately. Smallish displacement means good highway manners (30+mpg likely), short stroke means it'll rev (7500k rpm redline)and it should produce an easy 350whp/tq. More power. Better economy. Longevity to boot. The 4.8 is cheap ($300 at the local yard for a low mile unit), parts are readily available and it sounds cool.
Armitage
Armitage Dork
10/20/14 3:26 p.m.
If I had the fabrication skills to do it, I'd love to swap a DSM or EVO motor in. 4g63t or 4b11t, take your pick. An easy 300-400 hp/tq would be sweet in an 8. The problem has always been lack of RWD transmission options.
wvumtnbkr
10/20/14 3:28 p.m.
F2T and use the stock trans and rearend?
fidelity101
fidelity101 UltraDork
10/20/14 3:32 p.m.
20b
m4ff3w
m4ff3w GRM+ Memberand UberDork
10/20/14 4:29 p.m.
2.8l TT EFI V6 from a later Maserati Bitrouble!
NOHOME
NOHOME MegaDork
10/20/14 4:52 p.m.
Any government organization going to be peeking under the bonnet?
And as always, its cheaper to be on the lookout for and stockpile a spare Renesis than to perform any kind of a swap. Swaps are hard, they take a lot of time and nickle and dime you to death. Then you get to De-bug the thing. If you do manage to find a spare Renesis and keep it on the shelve, you just know the damn thing will run forever.
Curmudgeon
Curmudgeon MegaDork
10/20/14 5:04 p.m.
Renesis is the way to go. If you insist on unbalancing the car, then I'd go Lexus V8 of some flavor, at least that way you get a lightweight motor capable of some serious revs, much like the original design idea.
Driven5
Driven5 UltraDork
10/20/14 5:31 p.m.
Swap F20C into RX-8, and Renesis into S2000...Embrace the hate.
DaveEstey
DaveEstey PowerDork
10/20/14 5:39 p.m.
2.3 turbo MZR
10/20/14 5:44 p.m.
Driven5 wrote: Swap F20C into RX-8, and Renesis into S2000...Embrace the hate.
I like this guy.
MG Bryan
MG Bryan SuperDork
10/20/14 6:24 p.m.
I agree with the first half of this entirely.
pres589 (djronnebaum)
10/20/14 6:46 p.m.
F2T
Knurled.
10/20/14 7:02 p.m.
BRAP ALL THE THINGS
http://www.youtube.com/watch?v=-PzDbERNb4M
Knurled.
10/20/14 7:14 p.m.
In case that isn't enough, here's an FD: http://www.youtube.com/watch?v=up_O2unwbro On the street: http://www.youtube.com/watch?v=r4efvIx5cVU
singleslammer
singleslammer PowerDork
10/20/14 7:18 p.m.
I think that the LNX (?) is a sweet middle ground. Not as much weigh as an LSX and 300hp is a solid number for that chassis.
Fitzauto
Fitzauto Dork
10/20/14 8:17 p.m.
Gotta say a VQ37 would be fun. But im biased.
oldopelguy
oldopelguy UberDork
10/20/14 9:21 p.m.
3800 V6 with Camaro transmission, turbocharged of course.
Swank Force One
Swank Force One MegaDork
10/20/14 10:29 p.m.
13B. Huge peri-port.
BrokenYugo
BrokenYugo MegaDork
10/20/14 10:51 p.m.
Bobzilla wrote: 4.8 truck engine, cam/valvesprings, FAST intake w/90mm TB tuned to run appropriately. Smallish displacement means good highway manners (30+mpg likely), short stroke means it'll rev (7500k rpm redline)and it should produce an easy 350whp/tq. More power. Better economy. Longevity to boot. The 4.8 is cheap ($300 at the local yard for a low mile unit), parts are readily available and it sounds cool.
I'd guess closer to 450, but yeah, that and a 0.5:1 6th T56.
DWNSHFT
DWNSHFT Dork
10/21/14 1:21 a.m.
Audi 4.2l V8. Compact, light, good power.
unevolved
unevolved SuperDork
10/21/14 9:30 a.m.
Knurled wrote: BRAP ALL THE THINGS http://www.youtube.com/watch?v=-PzDbERNb4M
Jesus.
scardeal
scardeal SuperDork
10/21/14 9:40 a.m.
I think the easiest non-rotary would be cobbling together a 2.0 or 2.3 turbo.
NOHOME
NOHOME MegaDork
10/21/14 9:56 a.m.
Why does that think remind me of a dead Dalek?
1 2 3 4
BZV27up95lOCi8BnOAvwcUJjMgao6A6LhfrL6Lkk6w8RrRh5eQRC2I2vvhF4CLBV
