ReverendDexter
ReverendDexter Dork
4/29/10 11:02 a.m.
Am I the only one that read the requirement is UNDER 100hp?
And yes, rotaries are HEAVY. A turbo 13b weighs as much as a 5.0. They just act like a light motor because they're so short (length) and short (height), and thusly keep all that weight near the center of the car. Awesome for weight distribution and polar inertia, but not for overall lightness (else I'd think they'd be MUCH more popular in Locosts). They're also more power than the OP is looking for.
96DXCivic
96DXCivic Dork
4/29/10 12:35 p.m.
Actually ditch the under 100bhp requirement. I will probably go with a RX-7 rear end. Just light and cheap.
96DXCivic
96DXCivic Dork
4/29/10 12:35 p.m.
In reply to mad_machine:
Which Alfa engine? The Spider?
alfadriver
alfadriver Dork
4/29/10 1:08 p.m.
mad_machine wrote: how about an alfa engine.. beautiful aluminum and not too big
Alfa engines are pretty big, for the displacement. Head is especially wide due to the comustion chamber and the direct bucket cams.
For size, the 2.0l and 1750 are almost exactly the same size, the 1600 is barely shorter, and the 1300 is just barely smaller than that.
Once you hang the intake and exhaust- they are wide city.
(on that note, I have seen an MGA with an Alfa 2.0l in it....)
Eric
96DXCivic
96DXCivic Dork
4/29/10 2:02 p.m.
So right now, engines I am considering are Toyota 4AGE, 3TC, 2TC and Swift G13 or G10. Also maybe if the price is right a Volvo B18 or B20 or Mazda GLC engine. I am going to do some research on weight and power.
tuna55
tuna55 HalfDork
4/29/10 2:43 p.m.
The B18 is 340 lbs with the flywheel and clutch, carbs and stuff... not bad for 50s era tech. They also redlined at 7000 RPM from the factory, yowzers. Camshafts, intakes and headers are available.
Raze
Raze HalfDork
4/29/10 2:48 p.m.
Alfa engines are pretty big, for the displacement. Head is especially wide due to the comustion chamber and the direct bucket cams. For size, the 2.0l and 1750 are almost exactly the same size, the 1600 is barely shorter, and the 1300 is just barely smaller than that. Once you hang the intake and exhaust- they are wide city. (on that note, I have seen an MGA with an Alfa 2.0l in it....) Eric
if you were going to go this route, miata would again be the answer as they're far cheaper and more ubiquitous than an alfa engine...
spitfirebill
spitfirebill Dork
4/29/10 2:51 p.m.
John Brown wrote: Suzuki Swift DOHC with Tracker transmission.
+2
mattbatson
mattbatson New Reader
4/29/10 4:39 p.m.
the swift GTI motor isnt all aluminum
Bobzilla
Bobzilla Dork
4/29/10 4:44 p.m.
mattbatson wrote: the swift GTI motor isnt all aluminum
Yes it is. I have 2 shortblocks in the shed that say otherwise.
OK... the oilpan is stamped steel.... but everythign else is.
Nicve thing about the G13B is the intake faces the perfect direction for a "ram-air" intake.
Fit_Is_Slo
Fit_Is_Slo Reader
4/29/10 8:10 p.m.
oooooooooo i know!!!! Cummins 4bt!
96DXCivic
96DXCivic Dork
4/30/10 12:18 p.m.
^ In no way is that light.
Keith
4/30/10 12:23 p.m.
Well, it's light for a Cummins...
alfadriver
alfadriver Dork
4/30/10 12:28 p.m.
The only think the alfa motor has going for it is the aluminum block, over the cast iron Miata- it's a very light motor. Just too bulky for this job, IMHO.
E-
4/30/10 1:08 p.m.
always the fiat 128 engine from the X 1/9... but I think something DOHC instead of SOHC would be better...
How about the DOHC Alpha engine from the Hyundai accent?
Bobzilla
Bobzilla Dork
4/30/10 1:18 p.m.
^ Cast iron shortblock.
What about an ecotech?
96DXCivic
96DXCivic Dork
4/30/10 1:25 p.m.
I guess I would an engine and transmission from the Sky or Solstice for the Ecotech swap. That seems a bit pricey. How would you go about covering either the DOHC Alpha engine or Fiat 128 engine to RWD? I do love the Fiat engine idea.
alfadriver
alfadriver Dork
4/30/10 1:25 p.m.
Bobzilla wrote: ^ Cast iron shortblock. What about an ecotech?
And the F duratecs are not bad either. Look for a 2.3l Ranger.
But if you want a carbed engine for simplicity... There are quite few aluminum block 4 cyl engines that were carbed.
Vega?
E-
tuna55
tuna55 HalfDork
4/30/10 1:28 p.m.
96DXCivic wrote: I guess I would an engine and transmission from the Sky or Solstice for the Ecotech swap. That seems a bit pricey. How would you go about covering either the DOHC Alpha engine or Fiat 128 engine to RWD? I do love the Fiat engine idea.
I don't have firsthand experience, but the ecotech is way cheaper and easier than finding a scrapped sky or solstice.
http://www.gmperformancedivision.com/content/pulse/54/ECOTEC_2.0L_LSJ_Chap_1&2.pdf
http://www.gmperformancedivision.com/content/pulse/27/Ecotec_Part_2.pdf
http://members.shaw.ca/warped00/bcjbody/buildbook.html
And there are regular old transmissions that bolt to it for RWD, but I don't know what they are offhand.
It's just way over you HP goals.
Bobzilla
Bobzilla Dork
4/30/10 1:46 p.m.
I still say the G13B Swift 1.3L mated to a tracker/sami 5-spd trans is the way to go.
tuna55
tuna55 HalfDork
4/30/10 1:52 p.m.
Bobzilla wrote: I still say the G13B Swift 1.3L mated to a tracker/sami 5-spd trans is the way to go.
I'd love to see this too.
Keith
4/30/10 2:19 p.m.
alfadriver wrote: And the F duratecs are not bad either. Look for a 2.3l Ranger.
The 2.0 isn't as tall and has a shorter stroke, should be a better sports car engine. There are enough guys putting throttle bodies on these things that there's gotta be an easily sourced Weber adapter.
EricM
EricM Dork
4/30/10 2:22 p.m.
Teh E36 M3 wrote: Damn, John beat me to it. I honestly think that any carbureted engine past '74 is going to be more complicated that an injected. I'd go for a 4age, or better yet, WAY better yet, G13b out of a Suzuki swift GTi. 1300cc, all aluminum, bolt to a samurai trans, and weigh very little. There are dual weber 40 kits if you are stuck on carbs, but they are also pretty easy to MS. Also there is a website showing how to do it: http://www.ado13.com/dohczuke/dohc.htm Good luck, and I'd be glad to lend my experience- I swapped a toyota 4age 20v into my midget.
+1 I was going to reference that exact webpage
EricM
EricM Dork
4/30/10 2:23 p.m.
Done
Bobzilla
Bobzilla Dork
4/30/10 2:52 p.m.
^ sEEN it. I want a Locost set up like this.
47pPyVW323kH9JKN5BMrJVEgC2u943yrLUK5V20BNOjEWyymRypHWnNzq391vXjr
