Trackmouse
Trackmouse HalfDork
2/28/16 10:46 p.m.
I want to build a dual Spring coilover setup. What in the fudge is the "spacer" called that goes between the two springs and cups them so they stay in uniform parallel to the shock body? Need them for 2.5" ID springs.
I've tried "dual spring spacer" "dual spring collar" etc.
johnnie
johnnie New Reader
2/28/16 10:51 p.m.
Coilover helper spring adapter? Have also seen it called stack spring adapter.
Knurled
2/28/16 10:53 p.m.
Floater?
2/28/16 11:01 p.m.
Eibach calls it a "coupler".
http://www.ground-control-store.com/products/description.php/II=11/CA=213
Trackmouse
Trackmouse HalfDork
2/29/16 12:15 a.m.
Thank you Keith!
Trackmouse
Trackmouse HalfDork
2/29/16 12:37 a.m.
Also. It seems I've had better results now with the term "spring divider". Who knew...
iceracer
iceracer PowerDork
2/29/16 9:33 a.m.
I was thinking of the tender. Not the coupler.
flatlander937
flatlander937 GRM+ Memberand Reader
2/29/16 11:53 a.m.
Dual rate slider in the off-road world at least.
U0wCNNbFPasja173uhvqiVL3dREG7aeMwJPinIPS8eWSFmBsqzdnPHb7k7iRE7Go
