I wasn't sure whether to post this here, or in the $200x classifieds.
I'm thinking i want another Celica instead of the Escort. Less stuff that i don't know on the Celica, can do ALL work by myself without asking for help, less head scratching, etc.... Working on the Escort has made me realize that especially for a DD, i should stick to what i know in an effort to save money and time.
So... i turn to you guys, because you hold the cars in decent regard as a cheap funmobile, to find out ballpark what it's worth.
Details:
It's a 1993 Ford Escort GT. Red, pealing clearcoat. Straight body, some dings here and there, no major damage. Slight rust above rear wheel wells, again, not major. Not completely rotted out, just surface rust.
Interior is passable. Door panels are dirty, and have been glued back together at some point. Has a stereo in it out of some other ford product, i think only one speaker works. I haven't tried to figure out what the issue is.
Underbody looks GREAT. Typical surface rust on control arms, NO structural problems, no holes in floors. Slight exhaust leak.
Has a set of stock wheels painted black, with decent condition tires.
Recently replaced: Clutch, transmission, lower tranny mount, shifter bushings, suspension swapped out for Tokico Blues/Eibachs, full tune up done, oil pan and valve cover gasket, new brakes, new battery, new OEM intake hose, new air filter.
Has 53k miles on the odometer, title is exempt but clear, i think it probably has 153k miles, DEFINITELY not 253k, it's way too clean underneath for that kind of beating. If the title didn't say exempt, i would believe the 53k.
Spares: full sunroof assembly, transmission with bad 4th gear, stock suspension setup, spare complete good condition BP head, stock fogs, assorted control arms (i think i have all 4), 2 sets of good condition door panels, 3-piece wrap-around GT wing, spare set of wheels.
Runs and drives fine.
What do you guys think i should ask for it? I'd like to get at least $1500 out of it, if i can't get at least close to that, i'll just suck it up. Do you think it's plausible to ask $2000-$2200 for it?
