stroker
stroker PowerDork
4/21/23 10:09 p.m.
I should know what it is, but I do not.
Javelin
4/21/23 10:21 p.m.
It's a diesel for sure. Looks like a 7.3 maybe?
ShawnG
ShawnG MegaDork
4/21/23 10:21 p.m.
Diesel of some sort.
Probably Ford, looking at the bellhousing.
Edit:
I see a HPOP assembly on the front of the engine. Powerstroke.
It was left behind for a reason.
It's probably a boat anchor.
02Pilot
02Pilot PowerDork
4/21/23 10:22 p.m.
It's free. What else do you need to know?
jgrewe
jgrewe Dork
4/21/23 10:53 p.m.
7.3 powerstroke is correct
Robbie (Forum Supporter)
4/21/23 11:07 p.m.
Probably worth like $15 in scrap.
A 401 CJ
A 401 CJ GRM+ Memberand SuperDork
4/22/23 10:38 a.m.
They're 850 lbs so whatever that works out to.  I always found it interesting that the 5.9 Cummins though was 1150 lbs.
Curtis73 (Forum Supporter)
4/22/23 7:21 p.m.
Holy sweet Jeebus... do I see an SAE bellhousing on top?
That is worth a lot to me.
And 7.3 strokes are fantastic engines.  That one might have seen better days, but they're a 350k engine.  If it was a running/driving example, they'll easily bring $2000.  Reman longblocks go for $4000.  Complete engine/wiring/ECM can bring $3000 sometimes even with high miles.
Patrick
4/22/23 9:20 p.m.
In reply to A 401 CJ :
That's about $85 based on the $200/ton I got last week
jgrewe
jgrewe Dork
4/22/23 11:10 p.m.
Not sure about the SAE designation # on the powerstrokes but I have a couple of those adapters floating around the shop if you need one.
4/23/23 9:45 a.m.
Don't need, just crave.  Back in the day I went on a quest for all the SAE bellhousings I could find.  They're like the ultimate in certain trans swaps on the cheap.  I looked forever for a #5 or #6 for a VW because someone said it existed.
If you had a CBOP or MB SAE housing, I'd be asking for your Venmo.
Yd1IUdYVADa3JxjE84OXt0AWdiEvWjBR80tR3QfDwq0OWxPhBmG9PcPsdVGd62E2
