Japspec
Japspec New Reader
4/15/20 6:46 p.m.
Hi everyone. I have yet another sheet metal question. So my welding skills are horrific and I have a few small holes I would like to fill in the metal. I tried a few things that I researched but to no avail. I even tried soldering some metal onto it with my soldering iron but it would just ball up and slide off.
I have some body filler that I'm going to use to smooth out some spots, but I don't want to have moisture go into the body filler from behind these small holes and cause corrosion issues later on down the road. So, I thought of maybe using a little bit of JB Weld to cover them up before using filler, priming, and painting. Would that be fine? Anyone have any other ideas?
wheelsmithy (Joe-with-an-L)
wheelsmithy (Joe-with-an-L) GRM+ Memberand UltraDork
4/15/20 6:54 p.m.
Body filler of your choice should be fine. Seam seal the back for extra protection.
I just used JB weld on my project car (so I can go partial bare metal finish) for the same kind of thing. I can't report how it will hold up, but it's strong stuff. If you want, I say go for it.
Streetwiseguy MegaDork
4/15/20 7:13 p.m.
Or you could weld up the spots and grind them down.  A few spot welds would make that happy.
Japspec
Japspec New Reader
4/15/20 7:19 p.m.
Thanks! I think I might think about the JB Weld, since I'm paranoid about moisture somehow finding its way behind the rocker and being absorbed by the filler.
I could give that a go. I'm just afraid of blowing right through, but I guess a split second should be enough to get a good seal.
73lyfldbbCdHrIRqhPOllQ7QlHywNF7hG64cLvaX8NzRFkM4dSHvvIvjElbpE7Sr
