RacingComputers
RacingComputers GRM+ Memberand HalfDork
8/28/24 11:40 a.m.
37 year old IT -B Ford Mustang is available locally
Built as Race car, no title, but clean VIN
Is this too NEW for Vintage?
Too under powered for anything but Lemons Racing?
Seems well put together, has SCCA Log Books, spare engine, transmission, rear end and etc..
Would require the purchase of a trailer to get to events.
Thoughts??
Mr_Asa
Mr_Asa MegaDork
8/28/24 11:50 a.m.
Vintage varies due to region and organization, doesnt it?
In 3 years it will be 40 years old,  that'll have to be vintage, right?  If so, sounds like you can run it in other stuff for a few years till you get to vintage.
Gearheadotaku (Forum Supporter)
Gearheadotaku (Forum Supporter) GRM+ Memberand UltimaDork
8/28/24 12:12 p.m.
Ive seen early miatas in vintage events, so it should be eligable already. Autocross it? Hill climbs? Open road? Cheap enough to challenge?
wvumtnbkr
wvumtnbkr GRM+ Memberand UltimaDork
8/28/24 12:26 p.m.
It's WAY underpowered for lemons racing as well.
Itb would be the 4 banger NA, right?  Even 10 years ago there were a few of those racing in lemons and they were dangerously slow.
Tom1200
Tom1200 PowerDork
8/28/24 12:30 p.m.
A few vintage groups have started allowing IT cars. I would check with them.
I seem to recall the groups in your area being one of those groups.
The vintage group I run with would accept the car in one of the catch all classes.
IT cars are and always have been a great way to go racing.
RacingComputers
8/28/24 12:55 p.m.
Thanks for the update and input
It is not challenge priced.
4 Cyl 2300 Ci LIMA power plant
5 Speed transmission, 7.5" Rear end with 4.10 welded fears
4 Lug suspension with disks on all 4
Tk8398
Tk8398 HalfDork
8/28/24 1:00 p.m.
Can you still run an IT prepped car in the SCCA street autocross class? That could be fun if so.
tester (Forum Supporter)
tester (Forum Supporter) HalfDork
8/28/24 1:42 p.m.
In reply to wvumtnbkr :
I think it would make a fun Lemons car. A team could run it as a 4 cylinder for a few races, upgrade the axles, brakes, etc, and then convert to a V8 or something later.
Driven5
Driven5 PowerDork
8/28/24 2:15 p.m.
Alternatively, turbo lima lemonstang.
L5wolvesf
L5wolvesf Dork
8/28/24 2:43 p.m.
This
Have you considered racing it as is? Then see where that takes you.
RacingComputers
8/28/24 4:20 p.m.
Thanks for the feedback
Racing it AS IS would be the plan,  (after a safety inspection) assuming we can find somewhere to race it.
Tom1200
Tom1200 PowerDork
8/28/24 4:58 p.m.
In reply to RacingComputers :
You could run it in any number of local SCCA club races.  Doesn't CCR-SCCA have club races at CMP? I think they also do some track events at Charlotte Motor Speedway.
8/28/24 5:45 p.m.
HSR will likely welcome it. What makes a car eligible for vintage and historic racing? Let’s ask our friends over at Classic Motorsports. :)
RacingComputers
8/28/24 5:46 p.m.
Will have to check.  The only issue with Charlotte is there is a WHOLE LOT of hard concrete walls to HIT if I run out of talent.
However and 87 Fox body racer is a lot less valuable than the maxed out, overbuilt 2005 we just finished.
Good  luck at Buttonwillow
racerfink
racerfink UberDork
8/28/24 6:19 p.m.
I'm curious as to why you call it an "Ex" ITB car?
RacingComputers
8/28/24 8:02 p.m.
Has not been run in over a year, so I guess a better description would be RETIRED ITB Race car
wvumtnbkr
8/28/24 8:49 p.m.
I don't think you understand how slow it is.  A stock 1993 Plymouth voyager minivan would absolutely smoke it on a road course.
wvumtnbkr
8/28/24 8:50 p.m.
You won't be anywhere near the walls.  I'd be surprised if that hits 80 mph at the Charlotte roval.
Tom1200
Tom1200 PowerDork
8/28/24 9:14 p.m.
I can confirm an ITB Mustang will do at least 95mph. I raced against on in the 90s and we'd go down the back straight together.........my car would do 95 mph.
Tom1200
Tom1200 PowerDork
8/28/24 9:15 p.m.
Well just don't run out of talent.
racerfink
racerfink UberDork
8/28/24 10:23 p.m.
I think you grossly underestimate an ITB class race car.  When you come out of a corner going twenty miles an hour faster, that minivan would have to make a LOT more horsepower to make up the difference before the braking zone for the next corner.
At Sebring in 2014, I got to ride with Andy Pilgrim in a bone stock 2nd Gen CTS-V Sport, a car built for performance driving.  We did a lap at 2:35 in that car with 420hp, Brembos, and sporty Michelins.  The lap record for Spec Miata at the time was 2:35,  A good Spec Miata at the time put 120hp to the ground.
stafford1500
8/29/24 6:00 a.m.
Allow me to enable. I have a trailer you can use to pick it up.
akylekoz
akylekoz UberDork
8/29/24 6:30 a.m.
Let me know if you have any questions, we have been running a 4 cylinder 89 Mustang for....lots of years now.   Durable, cheap on consumables if it handles well mid pack class B.
wvumtnbkr
8/29/24 6:30 a.m.
A spec miata is WAY faster than an itb 4 cylind3r fox body.  The miata has 30 MORE hp than one of these turds and about 600lbs less weight.  These came out of the factory with 90hp and 2700+ lbs!
I Raced one in lemons a few times.  It's painful.
ddavidv
ddavidv UltimaDork
8/29/24 7:07 a.m.
V8 swap.
NASA American Thunder class.
QCudAZCqV6RkKO4si68eA3oTau0ZnU92245z3sdDMdVforzH02PsT84kExjD7Yh5
