What wheels/ cars share the same bolt pattern as a 90 CRX? I saw a late model Civic with steel wheels the other day. It had 4 lug nutsat 15" diametre and the wheels were a dead ringer for my factory steelies in 13" diametre. I am going to go to pull-a-part and see what I can find but want to know if they will fit. Is there a data base where I can cross reference the info? I think pull-a-part has an interchange data base but i want to know if there is any thing in the yard before I go down there.
Thanks in advance.
Bolt pattern on EF-chassis CRX/Civics is 4x100mm. Wheels from any 4-bolt Civic or Integra should work.
KATYB
HalfDork
8/6/11 1:24 a.m.
what rex said if its 4 lug and honda it most likely fits perfect.
4 bolt Honda Civic/Integra(not Accord), Miata, VW Golf/Jetta thru '99.5(except VR6), Toyota Tercel/Corolla should all work well. There are plenty of others I'm forgetting...
From this list you should manually be able to find what fits. Be sure to pay attention to Center Bore size.
http://adaptitusa.com/referencebook.htm
An easy answer for you is BMW 4x100 "Bottle Cap" wheels from am '84 to '91 BMW 3 series.
4 rims with tires for $250
http://atlanta.craigslist.org/nat/pts/2525100803.html
$75 for 5
http://atlanta.craigslist.org/nat/pts/2526426491.html
Full part-outs:
http://atlanta.craigslist.org/atl/pts/2531392604.html
http://atlanta.craigslist.org/atl/pts/2516055024.html
I believe that Honda hubs are 56 mm diameter. My Miata and Scion (Toyota) rims are all 54 mm diameter for the center hole. They won't go on a Honda, or my MINI for that matter. VWs are 57 mm,MINIs and Hondas are 56mm,Toyotas and Kias are 54mm. I can't speak to the hub diameter on any other brands.
KATYB wrote:
EGT FANBLADES!!!!!!!
This, preferably the 1993 variant, since they were the best!
BMW basket weaves will fit great, too.
mw
HalfDork
8/6/11 10:08 a.m.
In reply to 92CelicaHalfTrac:
I'm pretty sure EGT used the 54mm hub bore, so they won't fit a honda without machining.
Most German stuff is 57.1, Mazda and toyota at 54.1 and Honda is 56
KATYB
HalfDork
8/6/11 2:15 p.m.
easy enough to hone out the bore by 2 mm tho to make them fit. and yes 93's were the best. didnt some years not even come with them directional side to side wise.
why is it that bottlecaps looks good on everything BUT bmws?
Arent bottle caps 14"? Im looking for 15" steelies that look similar to my factory steelies.
I thought that any Honda lug would work. Im off to the junkyard first chance I get. Maybe Ill find some with usable rubber on them.
Don't get accord or prelude stuff!! And stay away from Nissan, Mitsubishi and fords
