DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
5/5/21 12:51 p.m.
As the title asks, what's your preferred magical oil for a 5-speed Miata NB transmission? I'm going to drain and refill one of these days . Car has 120K miles on it and I'm assuming it's the original oil in it now.
thatsnowinnebago
thatsnowinnebago GRM+ Memberand UltraDork
5/5/21 12:55 p.m.
Can't go wrong with Redline MTL. Don't forget the turret oil and new shifter boots.
Professor_Brap (Forum Supporter) UltraDork
5/5/21 1:02 p.m.
Ford mtf.
therieldeal
therieldeal Reader
5/5/21 1:15 p.m.
I had the unknown oil in my '99 replaced with Redline MTL a couple years back during a clutch job.  I was hoping it would help with my slightly crunchy 1-2 and 2-3 shifts, but unfortunately I didn’t notice much if any difference.
I’ve heard good things about the Ford/Motorcraft XT-M5-QS, but I can’t bring myself to drain & waste the MTL just yet :)
infernosg
infernosg Reader
5/5/21 1:25 p.m.
I've used Redline MT90 and Ford/Motorcraft XT-M5-QS in my RX7, which has essentially the same transmission. Other than the higher price point of the Ford/Motorcraft oil I didn't really notice any difference between the two. The 6 speed Miata guys rave about it though. For Redline I always thought MTL was too thin (75W80) and that MT90 (75W90) was the correct weight. I wouldn't expect miracles. Nothing is going to fix worn synchros or bad bearings but going with any high quality, synthetic GL-4 oil is going to be better than what's in there now.
I switched from Redline to the Motorcraft unicorn tears and the improvement was dramatic, much to my chagrin.  It really is worth the extra money, it was a night/day difference in how the car shifts.
calteg
calteg Dork
5/5/21 1:28 p.m.
Ford MTL was the hot ticket many years ago, don't know if that's the case now
WonkoTheSane
WonkoTheSane GRM+ Memberand SuperDork
5/5/21 1:30 p.m.
I've tried the Motorcraft, and agree with Infernosg, it's great, but it's not better than RedLine MT90.  I've used MT90 primarily for the past 20 years with good results.
I will say that I was not impressed by Mobil1 75W90.  I had a rear transmission seal fail and dump a lot of fluid once and I needed something in a hurry so I grabbed the M1 off the shelf.  It was significantly more notchy than the RedLine, and switch back a short time later made it smooth again.
I've also been less than impressed with Royal Purple.  I had a car I temporarily owned that the syncros were going out on like thereildeal (drivable but notchy), and I figured I'd spend the big bucks on RP.  It was about as bad as the Mobil 1, so I switched it out to RedLine before selling it.
bluebarchetta
bluebarchetta Reader
5/5/21 1:49 p.m.
I've run Redline MT90 and Motorcraft XT-M5-QS in my '91 Miata.  Either one is way better than the original fluid.  On a cold morning (< 40°F), the first few shifts with Redline are a little notchy/stiff until the trans warms up.  First few shifts with the Motorcraft are always smooth no matter the temperature.  Other than that I haven't noticed a difference between the two.
5/5/21 2:23 p.m.
MT90 is a good option for hard working transmissions as long as you can give it time to warm up. MTL has been the go-to for street Miata transmission for 30 years.
DeadSkunk  (Warren)
5/5/21 2:58 p.m.
In reply to Keith Tanner :
It's a street driven, supercharged NB, never tracked or autocrossed so sounds like I need to find the MTL then.
DeadSkunk  (Warren)
5/5/21 2:59 p.m.
In reply to thatsnowinnebago :
I did the turret refresh last fall, but the oil I used was likely Mobil1.
codrus (Forum Supporter)
5/5/21 3:27 p.m.
FWIW I use MT-90 because while people having been using MTL for decades without issues, it doesn't actually meet the specs that Mazda calls out in the owner's manual.
NickD MegaDork
5/5/21 3:47 p.m.
I've tried the cheap stuff, I've tried the Redline, I've tried the Lucas. I'll be damned if I could ever tell a difference.
mblommel
mblommel GRM+ Memberand Dork
5/5/21 3:53 p.m.
I used Ford/Motorcraft XT-M5-QS in both my '99s and loved it. In my second one it helped a lot with the abused 3rd gear synchro.
A friend recently bought an NB ( 5speed) that had just had the transmission changed with some flavor of Redline. He complained about it being very "crunchy". I suggested a change to the Ford fluid and he was pleased with the change. His issues went away.
I know some people swear by Redline, each to their own. I prefer the Ford fluid.
mxandcx5
mxandcx5 New Reader
5/7/21 5:49 p.m.
Ford/Motorcraft XT-M5-QS feels better than Redline in a Miata transmission, having experience with both. Worth my money and Rockauto sells it for much cheaper than dealer.  There is always a 5% off promo floating around the forum as well.
https://www.rockauto.com/en/parts/motorcraft,XTM5QS,transmission+fluid,13630
02Pilot
02Pilot UltraDork
5/7/21 6:23 p.m.
Anyone tried the Honda MTF in a Miata transmission? It was recommended for and worked wonders on my Saab C900. As a new ND owner who just turned the first 1k miles, I nonetheless feel the need to plan ahead.
rodknock
rodknock Reader
5/8/21 9:40 a.m.
I have used both Penzoil syncromesh and the Redline MT90 in the 5 speed Miata box.
Syncromesh probably wasn't a good idea because its quite a bit lighter weight than what Mazda recommends. Shift performance was great initially but seemed to degrade after a few thousand miles.
The MT90 felt the same as the Syncromesh but the shift feel stayed the same after 15k miles.
Donebrokeit
Donebrokeit UltraDork
5/8/21 9:59 a.m.
My trans was crunchy and hard to get in to second gear so I put the Redline fluid in, with no change. So I decided to try the Ford unicom blood and it feels like a new transmission no more grinding and second gear shifts like a charm.
5/8/21 11:10 a.m.
I've tried everything except Royal Purple in the RX-7 version of this transmission (I haaaaate that stuff) and I came to the conclusion that any benefits of MTL, MT-90, GL5, OMG etc. were placebo effect.  So I just get whatever gallon jug o'gear oil is cheapest at the parts store, maybe cut it a little with some leftover ATF.
5/8/21 11:50 a.m.
My FD arrived with a transmission that was really balky and hard to shift, I had read that their synchros were somewhat fragile, so I started looking for a replacement.  Before I got around to doing anything about that though, I needed to replace the clutch, which meant changing the fluid.  Drained out some fresh-looking fluid that the previous owner had put in, replaced it with Redline and it was night and day, all of a sudden everything worked properly.
I have no idea what was in there, but whatever it was that transmission hated it.
JoeTR6
JoeTR6 Dork
5/8/21 12:13 p.m.
Another vote for the Ford MT fluid.  My MSM had a balky second gear synchro, so I tried Redline MTL.  It was better, but the old Mazdaspeed forum recommended the Ford stuff.  While it doesn't shift like a 5-speed, it's definitely better with that oil.
5/8/21 12:16 p.m.
The FD had an updated version of the RX-3/4/5 transmission, which had a reputation for finicky synchros.  Those were REALLY fragile, they had built in stress risers and could bend with one poorly-executed shift!
7GMd6tZlJADjdNVV9QzyDWvGAbVYfEe2HOce2eU3lL0DxED5hug3bw9F0uIXL8uA
