Coldsnap
Coldsnap HalfDork
11/2/15 8:10 a.m.
Looking at basic engines.. Sometimes I get confused why they both exist.
neon4891
neon4891 MegaDork
11/2/15 8:32 a.m.
One is cheaper, the other is much larger.
Although it is easy to look at one and scope creep up to the other.
pointofdeparture
11/2/15 8:36 a.m.
The Accord is physically a much larger car, mostly.
singleslammer
singleslammer UberDork
11/2/15 8:44 a.m.
I (6'2") easily fit in the back of a new Accord. That isn't happening in anything smaller, Civic included. This is like asking why does Chevy make a Cruze and a Malibu. They are different cars that service different groups.
Woody
Woody GRM+ Memberand MegaDork
11/2/15 9:23 a.m.
The Accord is much more nicely finished inside.
Coldsnap
Coldsnap HalfDork
11/2/15 9:24 a.m.
So if you commute 1 hour to work, get the accord. If you have a 15 min commute get the civic?
bmw88rider
bmw88rider GRM+ Memberand Dork
11/2/15 9:44 a.m.
Accord is better if you carpool with 2 other adults to work. Civic is a 2 person car with an occasional use of the back seat. As far as overall comfort, I've found the civic more comfy than the Accord but some find it the other way.
11/2/15 10:35 a.m.
A 2015 Civic is about the size and trim level of a 2005 Accord. Repeat for every 10 years back to 1980 or so.
jstein77
jstein77 SuperDork
11/2/15 10:54 a.m.
A 1980 Civic was a smaller car than the current Honda Fit.
80 Civic: 152 in long by 62 in wide by 53 in high
15 Fit: 155.7 in long by 66.7 in wide by 61 in high
iceracer
iceracer PowerDork
11/2/15 11:01 a.m.
Civic is a compact
Accord is a mid-size.
1988RedT2
1988RedT2 PowerDork
11/2/15 11:07 a.m.
Pretty sure you can't get the 3.5-liter 278 HP V6 in a Civic.
Chris_V
Chris_V UberDork
11/2/15 11:15 a.m.
iceracer wrote: Civic is a compact Accord is a mid-size.
This. Is this a serious question? Did the OP really not realize there are size categories for cars? His avatar is a Nova, which was, at the time a compact car that was the next class down from the intermediate Malibu, which itself was the next size down from the full size Impala. All could be had with the same 350 cid engine. Why do you think the different size categories of cars existed?
wbjones
wbjones MegaDork
11/2/15 11:58 a.m.
1988RedT2 wrote: Pretty sure you can't get the 3.5-liter 278 HP V6 in a Civic.
you can … but it takes some cutting and fitting
1988RedT2
1988RedT2 PowerDork
11/2/15 12:02 p.m.
Fair enough! I stand corrected.
So I should have said: "Pretty sure you can't get the 3.5-liter 278 HP V6 in a Civic as a factory option.
wbjones
wbjones MegaDork
11/2/15 12:03 p.m.
Coldsnap
Coldsnap HalfDork
11/2/15 12:03 p.m.
I meant more drive train and suspension wise... Not size.
Tyler H
Tyler H GRM+ Memberand SuperDork
11/2/15 12:24 p.m.
Fair enough! I stand corrected. So I should have said: "Pretty sure you can't get the 3.5-liter 278 HP V6 in a Civic as a factory option.
Challenge accepted. Coming to a crapcan EG Civic near you.
DWNSHFT
DWNSHFT HalfDork
11/2/15 3:13 p.m.
Well, this is what came to mind:
Datsun310Guy
Datsun310Guy PowerDork
11/2/15 6:07 p.m.
My 6'4" son fits fine in the back seat of my Gen 8 Accord. I also like the size of the Accord but when I compare the Dimensions of the two I am trying to convince myself to get a Civic Si.
chiodos
chiodos HalfDork
11/2/15 6:23 p.m.
Different engines and suspensions. Is that what your asking? The base model accord engine came up rated in the civic si if that clears any air. My girlfriends 8th gen (2008) coupe is a MASSIVE car. Her friend has a similar year civic and it's much more manageable yet isn't cramped. you people saying your 6'4" and fit in the back of a accord, try squeezing in a coupe, I'm 5'11" and my head is pressed against the headliner.
wbjones
wbjones MegaDork
11/2/15 8:31 p.m.
Datsun310Guy wrote: My 6'4" son fits fine in the back seat of my Gen 8 Accord. I also like the size of the Accord but when I compare the Dimensions of the two I am trying to convince myself to get a Civic Si.
borrowed a friends Civic Si .. the gearing makes it an absolute blast to drive … gas milage nowhere near that of the other Civics … but a lot of fun to drive
cca6LhzyyOMMWbJE2PdQcQ8c1kX82dX6nh8gAXfbV0m9rpOX4vRF7jXcogHi2EyY
